NB SE air-con
NB SE air-con
Hi Everyone, I'm not sure if this is the right spot to post in but as its a turbo.. Has anyone had any experience faulting an air-con on a NB SE before - Mine keeps blowing the high pressure line return thing apparently.
I've had awesome air-con with this car for ages. The high pressure line from the compressor to the condensor keeps leaking. Initially the air-con place recrimped the line and re-gassed. (air-con was great for 6 days). The same line leaked again. Then they replaced the high pressure hose itself. The air-con lasted less than two days before failing again - leaking dye etc so it is clear where its leaking from.
They have pressure tested, left the system with nitrogen overnight and held pressure. ran the car (i imagine in the shop, and probably a short drive - no doubt crunching into third )
As far as i'm aware the compressor, condensor etc are all original - save for the dry receiver thing. Their solution, which sounds like a guess is: The compressor is spiking pressure when its under load, hot and being dríven for a while. So replace the compressor and things should be good... trouble is i'm not sure whether we are just having a stab or replacing this compressor will just mask the underlying issue. Along with the SE compressor seems to be slightly different to the 'normal' NB8B/C models - I imagine this is because of the turbo bits on an SE.
any ideas, thoughts, help would be greatly appreciated - I'm located in WA if anyone knows a gun for air-con!
Brad
Brad
- greenMachine
Me too!
Another SE owner with dead a/c here - my problem seems to be the compressor, or the controlling electronics not turning it on. It is a work-in-progress ...
Yes, I believe the SE compressor is smaller than the regular NB one, other than that I know nothing!
My only suggestion would be to get a second opinion, so hopefully the gun a/c shop will be identified here soon! Have you reached out to the local MX5 community over there?
Sorry I can't be more helpful, will be following with interest though!
- ManiacLachy
Re: NB SE air-con
Oh, to have good A/C in an SE! Surely that's the dream, not 300whp
I had a bunch of A/C hosing work done after my turbo swap. The A/C is slightly cooler than the ambient air, the system is working, but it's not cold so something still isn't right.
I would love to have it working well, I just don't take the MX-5 out in QLD summer (and WA is looking even hotter right now!).
- KevGoat
Re: NB SE air-con
My SE aircon works well on open roads in heat, but around town in traffic, it struggles. It's by far the best of the MX's I've owned, but I still don't drive it on a hot day. My son's ND RF, by comparison, is awesome. Mazda has obviously fitted a much more efficient fan as there is much more air flow, so it holds the in car temperature way better.
Sent from my SM-G781B using Tapatalk
Re: NB SE air-con
Yeah when the air con is working it is unreal - it gets too cold actually!
its strange because both high pressure hoses have been replaced. if the air-con works when its gassed and there's no problem with the TX valve, compressor (because its doing its job and pumping/cooling), the condenser isn't leaking - and like i say its working. Then to me its kind of starting like how that high pressure hose is connected isn't right. if it spiked in pressure etc then surely the hose itself would split. not the connector?
any one wrecking an SE haha
- greenMachine
Re: NB SE air-con
MrBrad wrote:any one wrecking an SE haha
Ring Mania, there one being wrecked there recently.
Re: NB SE air-con
Haven’t logged in for years but have just had this issue myself.
Local aircon shop noted the gas had leaked out on mine so refilled it. After that, they also noticed the spike in pressure after a few minutes of running.
He reckons that the radiator fans aren’t operating correctly in my car, specially the low speed mode which is usually used for the aircon. As a hack, he’s wired up the high speed relay to come on when the ecu / aircon kicks in.
So far, I’ve still got cold air, but I’m conscious the motors will likely burn out at some stage.
Anyone got any recommendations for replacement radiator fans? Mania has new ones but they’re $$$!
- greenMachine
Re: NB SE air-con
I have fan motors coming out of my ears, if that is what you want.
SPAL seem to be popular as aftermarket, don't know where the deals are though.
I am having my aircon checked out at mania as part of the new ecu install - not sure where my problem is, hopefully the new ecu will operate it and then all I have to do is get a new pipe made up to accommodate the different turbo.
Re: NB SE air-con
Came across SPAL in my search, no luck finding out which one would suit the SE yet, I do like the idea of brushless though!
2nd hand might be the trick in my case, though it doesn't look like all that many SEs in Aus swap them over as the OEM kit is pretty decent anyway so probably not many floating around
Fingers crossed its something simple!
- Roadrunner
- coyotes after you
Re: NB SE air-con
Mania replaced my cracked/leaking condenser when the engine was out and had the Ultratune next door regas it. Has been nice and cold for years now. 300hp and cold AC - the dream is achievable! (if only I could get a higher power cabin fan like the ND has!)
I do know of one fellow with an SE where the compressor failed, was unserviceable and a new replacement unit was over $1,500.00 ex Japan as the standard NB one wouldn't fit. That was also diagnosed by Mania.
Fingers crossed it's not the compressor.
MeepMeep
- greenMachine
Re: NB SE air-con
Roadrunner wrote: Fingers crossed it's not the compressor.
Everything is crossed that it is not the compressor!
I hadn't heard that figure, but I have heard of people needing a Bex and a good lie down when they got the quote
Re: NB SE air-con
Wonder what the part number is, as you could do a search on Amayama. Or do a generic search to see what other cars use the same compressor?
- Learner Driver
Re: NB SE air-con
I recently replaced compressor due to front seal leak. Cost was about 430, not that horrific. See pic for p/n
- Learner Driver
Re: NB SE air-con
dzzb wrote:I recently replaced compressor due to front seal leak. Cost was about 430, not that horrific. See pic for p/n
OK, pic did not come through - Number was CXS3089 (SANDEN P/N 3089)
- greenMachine
Re: NB SE air-con
Welcome to our little forum!
Did you do the job yourself, or have a shop do it? If the latter, might be useful to someone to know who, and whether you are happy with the job - see above comments on how well the SE aircon works. You might also put your location in your profile.
