Daffy's SE
Re: Daffy's SE
Postby Okibi » Tue Sep 06, 2022 1:11 am
Awesome! :mrgreen:
Daffy
Re: Daffy's SE
Postby Daffy » Sun Oct 09, 2022 9:22 pm
The recent turbo and intake reworks done and fresh tune sorted. With the injectors maxed out we are keeping things sensible (kinda… sort of :lol: ) with the boost and power output. There definitely is more power to be had, but at this time I’ll be leaving things as is. There is a little more to go with an engine protection system to be sorted, as well a reworked clutch. Safe tune @ 410rwhp with the original 1.8 BP4W strong as ever. :mrgreen:
viewtopic.php?t=73496
StanTheMan
Re: Daffy's SE
Postby StanTheMan » Sun Oct 09, 2022 9:32 pm
NUTS
greenMachine
Re: Daffy's SE
Postby greenMachine » Sun Oct 09, 2022 10:12 pm
Great stuff Daffy! :D 8) Very impressive numbers!
:mrgreen:
rascal
Re: Daffy's SE
Postby rascal » Mon Oct 10, 2022 7:21 am
:shock: Power triples within 1000rpm. That would be fun in traffic, not!
I see the running gear is built to handle it, but what tyres do you run to have any hope of traction/forward motion?
(Impressive build btw..)
Re: Daffy's SE
Postby bruce » Mon Oct 10, 2022 9:45 am
Wowee. I'd probably need a sick bag as passenger.
The American
Re: Daffy's SE
Postby The American » Mon Oct 10, 2022 11:05 pm
Nice work Daffy!
Re: Daffy's SE
Postby Lokiel » Tue Oct 11, 2022 6:57 pm
WON'T be calling "shotgun" EVER!
(scared the hell out of me last time with less power)
Daffy
Re: Daffy's SE
Postby Daffy » Sun Oct 16, 2022 11:14 am
rascal wrote::shock: Power triples within 1000rpm. That would be fun in traffic, not!
Cheers mate. At the moment I’m running Yokohama advan ad08r 225/45 R16 on 16x8 rims, but I’m thinking that I may have to look at 15x9 rims.
StillIC
Re: Daffy's SE
Postby StillIC » Sun Oct 16, 2022 12:19 pm
Daffy wrote:Cheers mate. At the moment I’m running Yokohama advan ad08r 225/45 R16 on 16x8 rims, but I’m thinking that I may have to look at 15x9 rims.
Why?
You have reasonably sticky tyres already of a reasonably large (therefore relatively heavy to standard) size/width.
Anecdote: my cousin used to have an RX3 he like to drag but it had plenty of wheel spin off the line on its RX7 6" rims and Yokohama A008 tyres. He bought a pair of massively wide (11" IIRC) wheels/tyres for the rear that solved his wheel spin issue; the car started lifting the front end at take off! But it was no faster down the strip. All he had done was add massive flywheels to the back of the car which required so much more energy to get rotating that they were more difficult to spin off the line. The car really dug in as a result of the extra inertia in the wheels. That's not the best way to solve wheelspin. Stickier tyres is.
StanTheMan
Re: Daffy's SE
Postby StanTheMan » Sun Oct 16, 2022 6:56 pm
but can you get sticker tires than those without risking heat cycle wear?
The American
Re: Daffy's SE
Postby The American » Mon Oct 17, 2022 6:56 am
It would be nice if there were more options in 15” and 245+ with suitable sidewall profiles.
I have some 15x9 for mine but don’t have tyres on them yet.
The Zork
Re: Daffy's SE
Postby The Zork » Mon Oct 17, 2022 8:19 am
I'd be running 255/40 x 17 AO50 at least with that much power. On mine I run 225/50 x 15 AO50 on the street as well as the track. I'm not interested in the ware. I don't drive it that much that it makes a difference. I think those tyres are the softest and gripiest you can get and made to withstand high power and torque.
BUT. I'd be looking at ways of making that 450+ over 9000 rpm instead of 7000 rpm. That sharp rise between 3000 and 4000 is a killer. Try to stretch the curve if you can. Talk to your tuner.
StuwieP
Re: Daffy's SE
Postby StuwieP » Thu Oct 20, 2022 8:55 pm
Lots of extra engine wear going from 7k to 9k rpm, though, right?
My NA6/SE build
Engine #1 RIP 04/07/2020
Re: Daffy's SE
Postby Lokiel » Fri Oct 21, 2022 2:10 pm
The Zork wrote::
That would require WAY too many $$$ and be cheaper/achievable with a different engine.
Users browsing this forum: No registered users and 67 guests
