Radio tombstone blanking plate
Re: Radio tombstone blanking plate
Postby bruce » Tue Jul 26, 2022 4:42 pm
96mm is the size of the hole in the 2 din frame. Thus adding the borders it 'looks' like the extra height of 123mm?
Postby bruce » Tue Jul 26, 2022 4:44 pm
2.5 din is 5 inches = 127mm. 123 is absolute max.
Postby 93_Clubman » Tue Jul 26, 2022 4:58 pm
bruce wrote:96mm is the size of the hole in the 2 din frame. Thus adding the borders it 'looks' like the extra height of 123mm?
Measurements from my 1993 NA8 are the measurements of the tombstone opening as my OEM radio & cubby don't protrude either outward or up or down or sideways. In other words, if I were to remove my OEM radio & cubby & replace them with a blanking plate, the blanking plate would need to measure 179mm x 123mm.
Postby bruce » Tue Jul 26, 2022 5:45 pm
I agree. Flush fit, edge to edge.
I just wonder if the 2.5 din 'loosely' translates to 123mm? (5 inch is 127mm).
Postby 93_Clubman » Tue Jul 26, 2022 6:11 pm
bruce wrote:wonder if the 2.5 din 'loosely' translates to 123mm? (5 inch is 127mm).
Reckon it does, hence why I put '7" wide x 5" wide approx' in my first post which included DIN sizes as it appeared from searches there was a slight variation.
Postby bruce » Thu Jul 28, 2022 8:54 pm
I may have found the answer;
FC0255235A Cubby
LA0255235 Blank plate
Available from Amayama for $72 delivered, will check Mazda.
But the tombstone is a M2-1028 item so looks longer and different HVAC opening. I will somehow check the opening dimensions.
WINNER! I blew up the second picture to lifesize and the dimensions seem correct 180mm X 122mm.
Postby bruce » Thu Jul 28, 2022 9:27 pm
It seems to match my earlier picture and the measurements check out;
Postby bruce » Mon Aug 01, 2022 12:53 pm
Ordered from Amayama.
Mazda said both parts unavailable. Quoted $141 and $137 for each.
Postby bruce » Wed Sep 07, 2022 11:31 am
Installed. Very neat;
PaulF
Postby PaulF » Wed Sep 07, 2022 1:39 pm
Nice result. No surprise that Mazda's quote was obscenely expensive.
Postby 93_Clubman » Thu Sep 08, 2022 12:31 pm
Looks good!
