Engine vibration
Mechdude
Engine vibration
Postby Mechdude » Sat Jul 02, 2022 11:35 am
Hey all, I have an NA6 long nose with 250k+km that I weekend drive.
Just recently I have noticed some harsh vibrations coming through the gear lever and dash. (Gear knob is rattling off)
Seems to be engine speed dependant.
The first buzz is around 2.5 -3, and again from 4-4.5
Engine and ignition seems to be running fine otherwise.
Likely causes?
Harmonic balancer, engine mounts?
Thoughts
Howard
Re: Engine vibration
Postby bruce » Sat Jul 02, 2022 12:23 pm
Could try parking the car, lifting the bonnet, giving the engine a good rev and see whatsa shaking under the bonnet.
ManiacLachy
Engaged
Postby ManiacLachy » Sat Jul 02, 2022 1:34 pm
Both motor mounts and the harmonic balancer are likely to be getting on if still original. They're both made with rubber that degrades.
You could give the engine a shove side to side to see if there's play. Also the harmonic balancer by hand, but when it degrades slipped timing is usually the issue.
Postby 93_Clubman » Sun Jul 03, 2022 12:39 am
Mechdude wrote:have an NA6 long nose
Exhaust manifold heat sheild & the other exhaust heat sheilds are all prone to buzzing & rattling during certain rev ranges when their mounts or tabs break, but not usually to the extent of rattling the gear knob off.
There's also a dash mounting point under the pside of the dash that eventually gives way that causes vibration.
Whilst rare, the long nose 1.6 & 1.8 have been know to suffer from much the same issue as the short nose 1.6.
