Tein electronic control question
pcmx5
Postby pcmx5 » Sun Nov 28, 2021 6:34 pm
I have just bought an NC2 with Teins and the electronic control.I am surprised that every time I start the car the motors return the suspension to the setting,ie it is not retained at the set damper rate when turned off. Seems totally illogical to me to do this every time ,I would have thought the settings would be retained until I decided to change them.Is there anyone on here who has Teins and can give some advice,Thanks Peter.
greenMachine
Re: Tein electronic control question
Postby greenMachine » Sun Nov 28, 2021 6:56 pm
Maybe should be wired to a 'always hot' circuit, though what that would do for battery life I don't know.
:mrgreen:
madmort
Postby madmort » Sun Nov 28, 2021 7:43 pm
According to Tein...
Resume Feature
The system remembers the damping force setting when the ignition key is turned off and automatically returns to the same setting when the key is turned back on. (Main power switch for the controller unit should stay on, for this function to work.).
As greenMachine said, might drain the battery.
pcmx5
Postby pcmx5 » Sun Nov 28, 2021 9:14 pm
Thanks guys.So basically it has to be on to hold the setting,I was thinking like a manual version it has turned it to the right setting so would stay there until you changed it .So a question to users then , has anyone has issues with the motor wearing out given it works every time the car is started?
StanTheMan
Postby StanTheMan » Sun Nov 28, 2021 11:07 pm
perhaps tein thinks they are artists .... and their dapmers should always be the way they intended.... :lol: :roll:
rascal
Postby rascal » Mon Nov 29, 2021 6:51 am
I’ve got teins and EDFC in my NB. It remembers the settings. It’s only if you disconnect the car battery or turn the unit off using its power button that you have to cycle to 0 so it knows where they are. (Note the unit needs an always on power wire much like a radio. Unit goes off with the key off and comes back on at key on with the same setting with no cycling)
I’ve had them nearly ten years and motors are fine. (And I disconnect often - cos race car)
It’s not like they are spinning ‘000s of revs each time. It’s a stepper motor doing 12 steps at max. I wouldn’t sweat it..
Users browsing this forum: No registered users and 44 guests
