NC Hardtop wiring harness for demister??? How to connect???
Luke
Re: NC Hardtop wiring harness for demister??? How to connect???
Postby Luke » Tue Aug 31, 2021 7:10 pm
93_Clubman wrote:Luke, if NC HT wiring is anything like NA & NB HT wiring, it fitted for, but not with the HT demister relay. On the NA & NB the relay ,when fitted, lives just behind the rear panel of the boot.
bruce wrote:He must have the wireless bluetooth connection option fitted.
What and what???
We've already established where the interconnect plug should be and there is no extra relay required.
Just to fill you two guys in.
My problem is the interconnect plug is not where it should be as I had to pull apart the whole rear parcel tray a year or so ago to change the BOSE amp so my wiring is likely under the plastic from when I put it all back together. BTW the NC parcel shelf has multiple pieces and does not come apart in 2 seconds. There is a reason the service that requires the intank fuel filter change is so much more expensive than any other service. It's a PITA.
As per madmort's picture earlier that's where the interconnect plug should be.
I have yet to dig in there properly yet as the hardtop removal is a 2 person job. The soft-top is currently folded down on the parcel shelf.
So no, nothing like a NA/NB. And that's not correct regarding NB8B's. You just swapped the cable from the glass softop demister to the hardtop, no extra relay. Hell why would a NB8A be different to a NB8B. NA I could understand with the plastic Window.
And an NC with Bluetooth. Ahhh, nope. Mazda Australia kept them in the stone age all the way to the end.
2022 BRZ 10AE
2021 GR Yaris
Luke
Postby Luke » Sat Sep 04, 2021 9:28 pm
Hardtop came off.
Pulled all the clips out of the main parcel tray to allow it to move around a bit. BTW You still cannot remove it like this as it interlocks with other parts.
I can touch the wiring loom with my finger tips but there is no way I can get it out from where it is.
Would require all the plastic to be removed again, including both seats.
Not worth the hours of work so I will have to live with the hardtop not having the demister connected.
Only way it would happen now is if something under there fails that needs changing, that would be BOSE Amp or the Fuel Pump.
2022 BRZ 10AE
2021 GR Yaris
madmort
Postby madmort » Sun Sep 05, 2021 10:11 am
As I said Luke, my demister was not connected all this last winter and I had no trouble at all with the rear window fogging or misting. The car is garaged so I suppose that helps.
2002 NB Titanium (sold), 2006 NC1 (sold), 2023 ND GT (sold), 2025 35th Anniversary Edition
Postby bruce » Sun Sep 05, 2021 11:51 am
Howabout a bit of bent wire and gently try to fish the loom out?
Luke
Postby Luke » Sun Sep 05, 2021 5:57 pm
bruce wrote:Howabout a bit of bent wire and gently try to fish the loom out?
Nope, not coming out that easy.
There is insulation and other stuff in there that it's between. Sort of wedged in there.
2022 BRZ 10AE
2021 GR Yaris
