Roadrunner wrote:Maybe I should swing a spanner off everything in the engine bay just to double check though!
It's my standard process to do a spanner check before each meet ...
Has caught a few things that would have become issues on track....
PaulF wrote:I'm pretty sure Dann chose the poly bush to be the same size as one of the control arm bushes. Rear upper control arm rings a bell, but I'm not 100% sure. Theoretically I suppose you could press an OEM rubber control arm bush in.
Users browsing this forum: No registered users and 22 guests
