Currently setting up my head with the 74lb springs. Building a forged turbo engine. I was concerned about using springs with such a heavy rate. But after a bit of research with a turbo build it sounds like they are required. My engine will be a track only so at full song most of the time i think they will be fit for purpose.
Now to grind some valve tips to give me a bit more valve lash clearance.
Valve Spring Rates
- Vehicle: MX5 Locost
- Vehicle: NB8B - Turbo
Re: Valve Spring Rates
GR124 wrote:Currently setting up my head with the 74lb springs. Building a forged turbo engine. I was concerned about using springs with such a heavy rate. But after a bit of research with a turbo build it sounds like they are required. My engine will be a track only so at full song most of the time i think they will be fit for purpose.
I am not sure what the deal is with the ratings on the Supertech springs. The 74lbs part number is what I used, and when I asked ST about them, they quoted 89lbs. The engine builder confirmed that they installed at 89lbs too. This is reusing the factory shims that the springs sit on in the head.
- Vehicle: ND - 2
Hi.
89lbs Would be about right I use the same in my NA but they are NB springs 1/16 inch shorter no problems with hydraulic lifters.
- plohl
It depends what seat you're using for them.
{edit: I just repeated myself from the first page}
plohl
plohl
plohl wrote:It depends what seat you're using for them.
ploh, do you refer to the spring "seats" or shims? not the valve seat?
I assuming you are referring to the valve on valve seat pressure will change depending on what spring seat/shim thickness is used?
- plohl
Sorry, that was a confusing.
I am talking about steel inserts which the valve spring sits on - spring seat. It's safe to assume the length from back of the valve (where it contacts the valve seat on the head) to the collet is constant, so changing the spring seat (closer or further away from the collet) will change the preload on the spring - which will change the seated force (/pressure).
that's probably even more confusing now.
plohl
plohl
clear as mud,,,,,,nah just kidding. It's what I thought you meant.
