Help cranks but won't start
Technical Guidance for doing those Tricky Jobs
Moderators: timk, Stu, -alex, miata, zombie, Andrew, PUR157
Postby Danny » Mon Jul 20, 2020 2:19 pm
Twice now, during a drive so normal operating temperature, my engine cranks strongly but won't start. It then clutch starts very easily after only a few metres of travel.
I'm suspecting a relay that has to be on for starting and switches off once running. (Had that problem in a previous car.) The car, an SE, has an Adaptronic piggy back so OBD2 is inoperative.
Anyone experienced that or know if there's such a relay, or other fix?
Re: Help cranks but won't start
Postby 93_Clubman » Tue Jul 21, 2020 4:12 pm
All MSM/SE manuals, including troubleshooting, but of course it could be Adaptronic piggyback related: https://drive.google.com/drive/folders/ ... 0xSNGVXMzA
CrazyRacer
Postby CrazyRacer » Wed Jul 22, 2020 8:58 am
Maybe check the ignition switch.
Could be the ignition circuits get power in the run position but not in the start position.
Postby Danny » Wed Jul 22, 2020 9:52 am
Thanks for those. I've been trying to replicate the issue on my driveway but hasn't recurred since the second time.
I do suspect the crank sensor and ignition switch. So far I've tampered with the throttle sensor and main relay. Don't see it as a fuel issue because it clutch starts so easily.
Red_Bullet
Vehicle: NA8 - Supercharged
Postby Red_Bullet » Wed Jul 22, 2020 9:55 am
Get the battery checked, Low voltage when cranking can cause the ECU to not run.
Postby Danny » Fri Jul 24, 2020 9:32 am
Hasn't recurred for a while now. Fitted a new battery as well. Oh, the suspense every time I take it out...
CrazyRacer
Postby CrazyRacer » Wed Jul 29, 2020 6:28 pm
My brother has classic British cars and tells me that the anticipation of the inevitable breakdown is part of the excitement of taking them out for a drive.
Postby bruce » Wed Jul 29, 2020 7:55 pm
Well, he must get a lot of excitement.
CrazyRacer
Postby CrazyRacer » Thu Jul 30, 2020 12:47 pm
bruce wrote:Well, he must get a lot of excitement.
He does. Keeps the tow truck guys on speed dial to deal with the constant excitment.
Return to “MX5 Technical Guides”
