Postby bruce » Tue Apr 14, 2020 1:52 pm
Remember not to drive thru any big puddles or standing water.
Snowmotion
Postby Snowmotion » Tue Apr 14, 2020 2:10 pm
bruce wrote:Remember not to drive thru any big puddles or standing water.
It's a race car only so not too much water on the race track and have a cover for those really bad days.
The factory mount is only about 20cm higher in the same location.
Postby Lokiel » Tue Apr 14, 2020 8:55 pm
Snowmotion wrote:It's a race car only...
- get rid of the honeycomb grille then, it's limiting airflow
Also consider adding a top "shelf" that forces all the incoming air to flow into the radiator.
Snowmotion
Postby Snowmotion » Tue Apr 14, 2020 9:20 pm
I like your thinking....
The grill may be difficult as there are 2 mounting points in the grill and delete these is not possible. But I will play around with that idea as it would limit airflow.
I like the idea of the "Top shelf" .. that will happen.
This was version 1.0 out on minimum thickness alloy so V2.0 will be using a little thicker alloy for better rigidity.
Do you know if the "top shelf should be at the very top or about 3/4 the way up?
Zed
Location: Swansea, WALES. UK (maybe NSW in a few years...)
Postby Zed » Wed Apr 22, 2020 10:47 pm
sandblasted a pair of mk2 front hub/uprights for my mk1, trial-fitted the eps column to test...
previous owner removed the pas and my mrs finds it a little heavy :?
and because.....
Rich.
MonkeyBritchers
Postby MonkeyBritchers » Thu Apr 23, 2020 7:17 pm
Finally fitted coilovers. They are Endless Function X hard springs. I know some will say "they are built for Japanese roads which are smoother than ours" but having travelled in Japan myself I can confirm their roads are in no better condition (and in some places actually quite terrible). The first picture is before fitment for comparison.
DMc2014
Postby DMc2014 » Fri Jun 26, 2020 1:32 pm
Installed some new/old audio. The 6 CD stacker/radio/cassette is from a 2002 Mazda Tribute and many of you will know it was a popular 'upgrade' for the NA back in the day. My first choice was to find an OEM radio/cassette but they are rare, lack the CD option and now over 30 years old. This unit gives me my 'green' fix and will play the old 'mix' tapes when I need a true escape back to the 90's 8)
Plenty of online resources on 'how to fit'. Unit was $145 on eBay (although I did buy a 2nd cheaper unit to pick up the cassette module and provide me with a 'practice' piece). Only downside so far - it's 2Kg heavier than the Alpine headunit it replaces! :frown: There's my next job..
pie5
Postby pie5 » Sat Jul 11, 2020 8:51 pm
NC2 Recaro interior into my 2006 NC1 softop.
So much nicer.
2019 Racing Orange 30AE #783
2006 Stormy Blue NC 2.4 GWR Header & Exhaust, Progress Springs, Koni Shocks, Whiteline Sways, Recaros.
ManiacLachy
Engaged
Postby ManiacLachy » Sun Jul 12, 2020 8:31 am
Those seats look great. Do they need adapters or different rails to mount?
pie5
Postby pie5 » Sun Jul 12, 2020 4:06 pm
ManiacLachy wrote:Those seats look great. Do they need adapters or different rails to mount?
Factory Recaro’s bolt straight in and include the airbags.
Ideal replacements but very hard to acquire.
Sent from my iPad using Tapatalk Pro
Postby Magpie » Mon Jul 13, 2020 10:58 pm
Went for a drive in the rain on Sunday...
ManiacLachy
Engaged
Postby ManiacLachy » Tue Jul 14, 2020 8:33 am
That's called swimming :mrgreen:
Red_Bullet
Vehicle: NA8 - Supercharged
Postby Red_Bullet » Tue Jul 14, 2020 10:15 am
Great photo!
greenMachine
Postby greenMachine » Tue Jul 14, 2020 11:45 am
Yes, great shot.
Is that a vortex coming off the notch in the endplate? Might be interesting to see what is visible in a high res image ...
:mrgreen:
Postby Magpie » Tue Jul 14, 2020 10:28 pm
greenMachine wrote:Yes, great shot.
:mrgreen:
I’ll ask for the high res.
Here is a 360 degree view (you can scroll in any direction)
https://www.facebook.com/watch/?v=2693090841010883
