greenMachine wrote:Bummer! It looks like oil is being thrown from the pulley, not just leaking down the cover/sump.
I know all about self-inflicted wounds. My car is sitting on the trailer, having dropped all its coolant. Following my removal and replacement of the turbo/manifold.
ETA: To stop hoses/fitting from leaking, I use the plastic plugs in male and female 10AN. Not a complete solution, but saves a LOT of cleanup, and is a nice solution for long or short term storage of hoses etc to stop oil getting out and wasps getting in . I think I bought a dozen of each from Speedflow so I always have a few on hand.
Yeah, I think it leaks from the front main seal, then is flung about by the crank pulley. Then when stopped a lot continues to drip straight down. It's still a worrying amount, more than I thought would come from a leaky seal. Good idea on the plugs, I'll look into that. If I'd had them on hand I would have made much less mess.
Lokiel wrote:Bummer - time to add a BE Oil pump and build the engine?
While an engine build probably isn't strictly necessary, I'm leaning towards it. If the car has to go in for more work I'd like to do it properly. And the EFR6258 I have planned would prefer a strong bottom end. A Boundry oil pump is mandatory on any BP engine build, in my opinion.
Custardtart wrote:I’m no expert on the NB but could it be the sump gasket or timing cover gasket? Is there a crank pulley seal there?
In my case, the leak is coming from above the sump, and no leaks from up high, though for sure those could be general possible sources. Almost certainly it's the front main seal, which is the crank pulley seal you're talking about.
This whole thing has me a little down. But hopefully there'll be some fun at the end. Super glad I have that Subaru wagon for daily duties, and grateful it's not a boring car to drive either.
