Removing NB intake manifold
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Sun Dec 29, 2019 5:15 pm
is a massive PITA. that is all.
rascal
Re: Removing NB intake manifold
Postby rascal » Sun Dec 29, 2019 9:48 pm
Actually I did this morning.. wasn’t bad at all... though engine wasn’t in the car. Makes it 100 times easier.....
No need to go by feel...
noobee
Postby noobee » Mon Dec 30, 2019 7:57 am
yes,patience is required.i also found that a good 3/8 drive set with wobble bars helped get the blind ones.my 1/2 drives were too big.
Mick
ManiacLachy
Postby ManiacLachy » Mon Dec 30, 2019 1:36 pm
I've heard it's a bit of a bear of a job. I've been planning a square top install but the horror stories have me a little concerned.
Let us know how you like the Skunk2. Beware, I've heard the throttle cable bracket is weak and can snap off pretty easily without re-enforcement.
StanTheMan
Postby StanTheMan » Mon Dec 30, 2019 2:34 pm
16bit wrote:is a massive PITA. that is all.
Its easier to actually remove the head & do it when the head is off the car.
Pity local shops charge $200 for a head gasket
16bit
Postby 16bit » Mon Dec 30, 2019 4:36 pm
it came off OK. but getting the skunk2 on is going to be the real problem. even less access to the underside nuts.
Postby Lokiel » Wed Jan 01, 2020 11:35 am
The underside intake manifold nuts are a HUUUUGE pain in the arse to access, way harder that the exhaust manifold.
I used virtually every combination of extension/wobble bar and flexi-joint I had to accomplish this (even using 2 flexi-joints for a couple of them), all from the top and reaching underneath since the MSM/SE has too much crap in the way to get at from underneath.
If you have small hands and arms, or have access to someone that does, it would be a little easier.
Just accept the fact that it will take a while, have plenty of tools available and look to see if you have any easier access to the lower bolts from below.
16bit
Postby 16bit » Wed Jan 01, 2020 5:15 pm
yeah i figure its going to take me many hours and lots of swearing. only have one flex joint may need another!
man it came with some aftermarket long studs and nuts. they are both sh*t. had to tap all the nuts and the studs don't seem great either. had to recut the thread on one of the studs too. oem is best!
rascal
Postby rascal » Wed Jan 01, 2020 9:43 pm
Sounds like typical skunk2 quality control...
16bit
Postby 16bit » Thu Jan 02, 2020 9:08 am
you are telling me. i had to re tap every single hole between the top and bottom section of the intake manifold before i could even get it together.
Postby bruce » Thu Jan 02, 2020 12:48 pm
If it was new I would be sending it back (I think you purch it from another user).
A quick goggle reveals there are fakes going around and claims that Skunk produce top quality items. I wonder if yours is genuine?
16bit
Postby 16bit » Thu Jan 02, 2020 2:18 pm
yeah i bought it off another forumite. i believe it to be original. the studs are aftermarket from somewhere else.
project.r.racing
Postby project.r.racing » Fri Jan 03, 2020 8:32 am
It aint pita until you do it on a transaxle fwd car with the bolts 10cm from the flywall :lol:
Users browsing this forum: No registered users and 50 guests
