StanTheMan
Postby StanTheMan » Mon Dec 30, 2019 7:48 am
Desperate times call for desperate measures . No place to do the work. Rego is due . So engine change was done in the street.
Sent from my iPhone using TapatalkImage
Postby 93_Clubman » Mon Dec 30, 2019 9:16 am
Well done Stefan - not ideal as you say, but at least you appear to be at the quiet end of your street.
Postby bruce » Mon Dec 30, 2019 9:27 am
Almost looks like an LS swap (if the white Commodore in the first picture was a bit closer...)
greenltd
Postby greenltd » Mon Dec 30, 2019 11:27 am
I like the refreshment stand
Sent from my SM-N920I using Tapatalk
Postby 93_Clubman » Mon Dec 30, 2019 3:27 pm
Indeed, reminds me of the Godfather! :mrgreen:
StanTheMan
Postby StanTheMan » Mon Dec 30, 2019 3:27 pm
greenltd wrote:I like the refreshment stand
Ha ha neither of us could touch it. It was too hot. Sure the water kept on disappearing LOL
LiteIsRite
Postby LiteIsRite » Tue Dec 31, 2019 2:05 pm
Let me begin this post by wishing you all a safe & prosperous 2020. This goes doubly for anyone affected by this most recent outbreak of bushfires.
While I was wiring up the new DRLs (separate post), having removed a headlight to improve access, I saw how corroded the outside of the reflector had become...
Seeing the inside surface of the reflector had become quite dull in places, I figured it was time to replace both these (original?) lights. Today I fitted new Raybrig units. The following pic shows one fitted (passenger side), in comparison to the OE headlight.
In the process, I cleaned up some surface rust on the retaining springs and screws.
”How you get there is the worthier part.” - Shepherd Book, Firefly
"Cherry" - Classic Red 1990 NA6 :NA6: [sold]
Postby Mr Morlock » Tue Dec 31, 2019 7:51 pm
Looks like Raybrig is actually Stanley- at least that what is said on the net. My guess is that Mazda may have used Koito originally. Both Japanese lamp makers tied into the car industry. Sure the back of reflector will deteriorate over 30 years but the actual reflector inside surface is the most important. The lighting game has been taken improved so much with leds and affordability - gas discharge did not seem to last long at all.
LiteIsRite
Postby LiteIsRite » Tue Dec 31, 2019 9:02 pm
Yes, Mr.M, Stanley is the manufacturer of the ‘Raybrig’ brand - apparently quite popular in Japan - and, yes, the lights I took out are branded ‘Koito’. From what I can tell, these headlights are aimed (pun intended) at cars with pop-ups. They do 7” x 6” rectangular lights as well. There’s even photos of NA’s on the packaging!
Postby KevGoat » Tue Mar 03, 2020 11:56 pm
new cat-back ...
Ummmm ... can't get image to orient correctly
ak_perth
Postby ak_perth » Wed Mar 04, 2020 8:39 pm
Love the new cat-back... :lol:
Here you go, right way round now.
Postby KevGoat » Wed Mar 04, 2020 9:04 pm
Thank you
Postby KevGoat » Sun Mar 22, 2020 9:16 pm
Yesterday finally washed it then we took it for a drive. Found this awesome sculpture in Strathalbyn that uses all sorts of metal parts ...
twr7cx
Postby twr7cx » Mon Mar 23, 2020 1:56 pm
Where did you purchase the Raybrig semi sealed beams from?
LiteIsRite
Postby LiteIsRite » Mon Mar 23, 2020 6:14 pm
