Wolfgang
Postby Wolfgang » Sat Oct 26, 2019 9:09 pm
Extracted nearly 30 years worth of I don't want to know what out of my seats.
Chuppa
Postby Chuppa » Thu Oct 31, 2019 9:31 am
Replaced fluids, belts, spark plugs, most seals and radiator/heater hoses.
Serviced the gear turret, replacing the insulation and lower gear boot. Installed a short shifter kit and a voodoo style spherical gear knob.
Swapped one of the horns for an after-market type. The sound of which is reminiscent of a 1970’s era family six cylinder sedan. The aural mix of this horn and the other one is horrible and super distracting - just what I want.
Installed generic $50 Chinese double din touch screen head unit. The previous stereo wasn’t working when I bought the car. Am impressed with the sound from the NB speakers.
Not much to do now except drive!
‎"We are all self-made. But only the successful will admit it."
Gladiator
Postby Gladiator » Thu Oct 31, 2019 1:24 pm
Finally fitted my front lip. I’ve only had it for a few years & don’t like to rush things. Image
Gladiator
Postby Gladiator » Sun Nov 17, 2019 3:13 pm
Today I fitted my dual tip corns exhaust. It took a fair bit of manipulation to get it to fit, & I’ve still got to go to Mr. Muffler & get a couple of hangers changed. It knocks going around roundabouts. ImageImage
Postby Lokiel » Mon Nov 18, 2019 12:11 am
Re-made+anodised Cold Air Box:
StanTheMan
Postby StanTheMan » Mon Nov 18, 2019 7:40 am
Changed a broken sump over. I knew I had a broken sump. I was still shocked to find these massive bits in it . So then a lot more than expected had to come off to insure no other bits were in the crank case. ImageImage
Sent from my iPhone using TapatalkImage
ManiacLachy
Postby ManiacLachy » Mon Nov 18, 2019 8:53 am
Gladiator wrote:Today I fitted my dual tip corns exhaust. It took a fair bit of manipulation to get it to fit, & I’ve still got to go to Mr. Muffler & get a couple of hangers changed. It knocks going around roundabouts.
They look great, mate. Still loving your paint job too!
Lokiel wrote:Re-made+anodised Cold Air Box
Every time I see up Gina's skirt I have to sit down for a little bit! Glad to see some progress.
StanTheMan wrote:Changed a broken sump over. I knew I had a broken sump. I was still shocked to find these massive bits in it . So then a lot more than expected had to come off to insure no other bits were in the crank case.
:shock:
Good work everyone. This weekend I swore a lot and finally got my car started again! She's not down on the ground yet, but this was a big relief!
Excuse the quality, this is a screen shot of a video sent to a friend to prove the running motor
Chuppa
Postby Chuppa » Fri Nov 22, 2019 10:23 pm
Jass performance upgraded gear boot went in today.
StanTheMan
Postby StanTheMan » Sat Nov 23, 2019 3:08 pm
Been furiously polishing the flat top IntakeImage
Gladiator
Postby Gladiator » Sun Nov 24, 2019 8:11 am
StanTheMan wrote:Been furiously polishing the flat top IntakeImage
Jesus Stan, that’s a lot of work! Looks good though.
LiteIsRite
Postby LiteIsRite » Sat Nov 30, 2019 7:28 pm
Added a pair of DRLs... and learnt a bit more about relays in the process 8)
”How you get there is the worthier part.” - Shepherd Book, Firefly
"Cherry" - Classic Red 1990 NA6 :NA6: [sold]
LiteIsRite
Postby LiteIsRite » Sat Dec 07, 2019 11:31 am
Sorry for the smartphone pics, but here's what the new DRLs look like from approx 50m and 100m away...
greenMachine
Postby greenMachine » Sat Dec 07, 2019 2:58 pm
LiteIsRite wrote:Added a pair of DRLs... and learnt a bit more about relays in the process 8)
… wired to go off when the headlights come on, of course! :wink:
:mrgreen:
LiteIsRite
Postby LiteIsRite » Sat Dec 07, 2019 6:09 pm
:mrgreen:
:D yep, that’s where the (normally closed) relay comes in :D
Chuppa
Postby Chuppa » Sun Dec 08, 2019 8:36 am
What did you learn? Did you run the relays from the accessory 12v?
