Daffy's SE
- StanTheMan
Re: Daffy's SE
did you tread about Gosbys 500 whp 1.6 OMGGTFO. LOL
- Daffy
Re: Daffy's SE
ninerwfo wrote:Stantheman - it is a BMW Getrag ZF 6 speed No worries about gearbox feel.
ninerwfo, thanks again for the great pictures and uploading the video (I’d be scratching my head a month trying to work out how to upload that!) I’m so glad we got a great day to take it for a good run after the touch up tune. Daz and I had to reattach a couple of hoses with stronger clamps that.....ahem...uhh..... blew off (???) after the little bit of spirited acceleration tests (as well as a very minor coolant leak)
I think that maybe another Nasho run be sorted out soon with a few of the others
- KevGoat
Re: Daffy's SE
Great to see the results after so much done. This build is just incredible...
- Custardtart
Re: Daffy's SE
Looks fabulous and wow that sound, like a fighter jet on full attack!!
NC1 - 2.5 opposite lock device
Lakeside 62.3
Lakeside 62.3
- Daffy
Re: Daffy's SE
KevGoat wrote:Great to see the results after so much done. This build is just incredible...
Custardtart wrote:Looks fabulous and wow that sound, like a fighter jet on full attack!!
Thanks for the compliments- (videos gratefully uploaded curtesy of ninerwfo at your request Custardtart )
Re: Daffy's SE
So very cool, love this car.
- SKYHI
Re: Daffy's SE
Great to see it all back together and running Daffy.
- Daffy
Re: Daffy's SE
I thinks it may be time to discard the aging fab9 motorbike coils for LS heavy duty update. Last couple of drives seen some spectacular exhaust flame of unburnt E85. Either a plug is on its way out (5mm gapped and most likely) but the LS coil conversion is inevitable- fix it once fix it right
- StanTheMan
Re: Daffy's SE
There is a video around about how good different coils are. It’s worth a watch . I was under the impression the Fab9 system was unreliable.
LS1 coils?
LS1 coils?
- Daffy
Re: Daffy's SE
After just on 4 years the Fab9 Denso coils are starting to break down. They held up well for such a mammoth task that was set, but time to employ the do it once do it right philosophy with an overkill solution. Enter the IGN1A coil. Got a set ordered from Haltech (cheaper than from Mercury marine) as well as teeing up some 10.5mm leads and running a new heavy duty wire back to the battery. Should just be (hopefully a no issue) a BIG spark plug and play set up. The plan is to down size and relocate the radiator overflow bottle to have a cooler spot to mount them as pictured. More to come.
- Daffy
Re: Daffy's SE
Its taken a few bloody agonising weeks, but the Haltech IGN1A coils have finally arrived
- ManiacLachy
Re: Daffy's SE
About time!
Now get them in and find what breaks next
Re: Daffy's SE
Now comes "The Fun Part", figuring out how/where to mount them
I'd start with looking at the SADFAB mount (the LS coils are round so are recessed into the bracket - you can't do that with IGN-1 coils though) for inspiration or the Singular mounts (you'll need the two rods to mount in the middle of the side brackets, one at top and one on bottom).
I see lots of cardboard templates in your future!
Mine are similar to the Singular mounts except I mount mine upside down compared to theirs since it gave me greater hood clearance:
Shortening the ignition leads is simple.
- Daffy
Re: Daffy's SE
Lokiel wrote:Now comes "The Fun Part", figuring out how/where to mount them
Gina’s engine bay is starting to look the business Lokiel . We have had a bit of time to plan the location for the new coils and the placement. The rad overflow will be eliminated and a smaller one relocated to replace, so that will leave a good amount of space to mount in the front right corner well away from the heat. The mounting bracket we have on the way is purpose built for these coils. Plan is to get them in, measure up for the new leads to be made as well as sorting out the rewire work. Should be underway starting Monday.
ManiacLachy wrote:About time!
Lachy, the bloody thing better play nice after this latest bout of hip pocket punishment
- Vehicle: NA8 - Supercharged
Re: Daffy's SE
Come on, stick all your spending in a spreadsheet and tell us, hide it from the missus, but tell us. hahhahahhaha
Users browsing this forum: No registered users and 112 guests
