Scoota wrote:Please don’t get the impression that I’m ignoring your advice. I’m considering your input and making my own decisions. If I diverge from your chosen path, please don’t be offended.
Your car your money your decisions
100mm trumpets are possibly still too short, but they will make a massive improvement in mid range over 50mm ones.
As mentioned, you may need to move the clutch master as well. This can be achieved by utilising the brake master and drawing fluid from there to the clutch with a hard line. I did this on mine for a while, it works.
Instead of the filters you are looking at consider something like a Pipercross setup and you can offset the trumpet holes a bit to move the filter towards the front of the car. This was done on mine when it was first built with ITB's.
The 'best' solution if running ITB's is to get rid of the brake booster, however this needs to bone with a bit of thought to pedal ratio and effort required. Mine has a modified pedal and some people are still surprised at how much effort is required to cause brake lock up. They have sat in the car and pushed on the pedal until the brake pressure sensor says about 600psi. What you will get from this is a linear brake pedal, how hard you press is how fast you stop...
Photo of John Pham's setup
John's half size radiator
This was sent to me last year and it is still something I enjoy listening to
https://www.facebook.com/kevinvinall/videos/10157896322373065/
