Gearbox rebuild – where to buy parts? (NA)
I've got a couple of gearboxes to rebuild. Does anyone sell a rebuild kit of the routine parts, or will I be going through the parts catalogues and finding all the individual numbers?
- 16bit
Re: Gearbox rebuild – where to buy parts? (NA)
you will likely need to get hold of a shop manual online. it will be the easiest way of getting all of the part numbers.
here you go.
https://drive.google.com/drive/folders/1Rbna5tua3aqD28BGkn4F5u0TgNJuuFTy
here you go.
- beavis
- Vehicle: NB8B - Turbo
16bit wrote:you will likely need to get hold of a shop manual online. it will be the easiest way of getting all of the part numbers.
here you go.
Oh hey, that's my Google Drive link!
For more things technical I have all sorts of info here: https://beavismotorsport.com/guides-tech
- 16bit
beavis wrote:16bit wrote:you will likely need to get hold of a shop manual online. it will be the easiest way of getting all of the part numbers.
here you go.
it showed up in google search for online mx5 shop manual. clearly indexed quite well on the google machine.
For the bearings and oil seals, they should be readily available at, or at least through, your local bearing supplier, probably considerably cheaper than from the dealer, gaskets etc. could be either made or replaced by a good flange sealant. Shafts and gears will be harder to source however.
