Wing mirror trim for NA
Paolo
Postby Paolo » Mon May 20, 2019 9:31 am
Hi,
I removed the driver's side wing mirror (non-electric) from my partner's NA on Saturday in order to tighten the bolt that holds the mirror in a desired spot.
I removed and then cleaned the glue from the channel of the black mirror surround and put it in "a safe place"...now after many searching episodes have come to the conclusion that it has left the building. :?
I am after a replacement for this mirror surround...it is the black plastic ribbon-like piece that looks a bit like a shoe lace that holds the mirror into its housing. The original one is the same shape as the mirror.
I have searched 'pinchweld', 'u-channel'. Just can't come up with the correct terminology to do a successful search.
If this material is not available as an aftermarket part, I will no doubt need to find a whole replacement mirror.
Does anyone have a lead on where I can obtain this trim?
StanTheMan
Re: Wing mirror trim for NA
Postby StanTheMan » Mon May 20, 2019 9:49 am
I have s replacement mirror. Classic red but I do have to check which side it’s from
Paolo
Postby Paolo » Tue May 21, 2019 12:55 pm
Hi Stan,
Did you find out if you have a driver's side or a passenger's side mirror?
Paolo
StanTheMan
Postby StanTheMan » Tue May 21, 2019 1:09 pm
Will be in touch tonight.
sorry I have tpo climb under The house :oops:
Paolo
Postby Paolo » Thu May 23, 2019 10:14 am
Call off the cavalry!
The missing mirror trim miraculously appeared this morning....have NO idea where it has been. It was humping the pedal of the kitchen recycling bin and I was just about to put my foot on it to lift the lid!
Treating this one as pure unobtainium and handling it with utmost care.
Thanks for your offer of help, Stan. I appreciate it.
Now off for a drive to see if the newly-tightened mirror pod remains in its set position...then the mirror and trim will be siliconed back into place.
End of drama... :P
StanTheMan
Postby StanTheMan » Thu May 23, 2019 10:25 am
pheew.
and I forgot again. Must be my age. Good to see you've found it. Treat it with care . they can be fragile.
Postby bruce » Thu May 23, 2019 11:03 am
Blame the missus (actually DON'T blame the missus).
Failing that, blame the dog/cat/budgerigar.
Paolo
Postby Paolo » Thu May 23, 2019 5:07 pm
:lol: :lol:
Users browsing this forum: No registered users and 155 guests
