Gearbox and Diff Oil Quantities
- madmort
The 02' MX5 calls for 2.1 US Quarts for the gear box and 1.06 quarts for the diff. When changing oil would I get away with 2 quarts and 1 quart? Just seems a waste buying the extra bottles if enough oil gets left behind to make up the difference.
Thanks.
Thanks.
- Vehicle: MX5 Locost
Re: Gearbox and Diff Oil Quantities
google tells me 2.1 Quarts is 1.98 litres so a two litre at the store. am I missing something?
FWIW, I just changed the oil in my 01 gearbox and it took almost exactly 1.8L (used graduated pump bottle to fill) before coming out the fill hole.
- madmort
Thanks Rascal.
Likewise, 1.8L for my '02 6 speed, & 0.8 - 0.9L for NB8A diff
- madmort
Yes.GR124 wrote:google tells me 2.1 Quarts is 1.98 litres so a two litre at the store. am I missing something?
- 1600Dave
I was wondering the opposite - where do you buy oil in quarts in Australia ?
That is a pointless question.
Redline oil and some others list both measures on the bottle.
1600Dave wrote:GR124 wrote:google tells me 2.1 Quarts is 1.98 litres so a two litre at the store. am I missing something?
You can only buy redline mt90 in quarts or gallons here..
Just for future reference, I've managed to fill both NA8 and NB8A 5 speeds with 2 qts of Redline each.
Similarly, my NA8 5 speed was filled by 2 quarts of Redline & Torsen 1 diff by 1 quart of Redline.
- madmort
magna_blue and 93_clubman Thanks. Did you notice any improvement in gearbox gear selection/feel with Redline?
- 1600Dave
rascal wrote:1600Dave wrote:GR124 wrote:google tells me 2.1 Quarts is 1.98 litres so a two litre at the store. am I missing something?
You learn something new every day.
I'm still getting over the joy of recently discovering diesel oil now comes in 7L bottles, no more having piles of random 10L drums scattered throughout the shed, all with 3L left over from every oil change on the Hilux
madmort wrote:Did you notice any improvement in gearbox gear selection/feel with Redline?
Did it back in 2006, so car had only done 50k kms, & GB was fine & remained fine. What I did notice recently when clutch was replaced & the mechanic drained the Redline GB & diff oil (without being asked), was that gear selection is not as good cold with the run of the mill Penrite he put in.
I've found the new Penrite Pro Gear GL4 better than the Redline MT90 in my 6 speed.
https://penriteoil.com.au/applications/car-4wd/gear-oils/pro-gear-gl-4-75w-90#/
Users browsing this forum: No registered users and 104 guests
