Gearbox and Diff Oil Quantities
madmort
Postby madmort » Thu May 16, 2019 11:22 am
The 02' MX5 calls for 2.1 US Quarts for the gear box and 1.06 quarts for the diff. When changing oil would I get away with 2 quarts and 1 quart? Just seems a waste buying the extra bottles if enough oil gets left behind to make up the difference.
Thanks.
GR124
Vehicle: MX5 Locost
Re: Gearbox and Diff Oil Quantities
Postby GR124 » Thu May 16, 2019 1:55 pm
google tells me 2.1 Quarts is 1.98 litres so a two litre at the store. am I missing something?
rascal
Postby rascal » Fri May 17, 2019 8:03 am
FWIW, I just changed the oil in my 01 gearbox and it took almost exactly 1.8L (used graduated pump bottle to fill) before coming out the fill hole.
madmort
Postby madmort » Fri May 17, 2019 8:41 am
Thanks Rascal.
RS2000
Postby RS2000 » Fri May 17, 2019 9:05 am
Likewise, 1.8L for my '02 6 speed, & 0.8 - 0.9L for NB8A diff
madmort
Postby madmort » Fri May 17, 2019 9:27 am
GR124 wrote:google tells me 2.1 Quarts is 1.98 litres so a two litre at the store. am I missing something?
Yes.
1600Dave
Postby 1600Dave » Fri May 17, 2019 7:51 pm
I was wondering the opposite - where do you buy oil in quarts in Australia ?
Postby bruce » Fri May 17, 2019 7:59 pm
That is a pointless question.
Redline oil and some others list both measures on the bottle.
rascal
Postby rascal » Sat May 18, 2019 10:16 am
You can only buy redline mt90 in quarts or gallons here..
Postby manga_blue » Sat May 18, 2019 1:39 pm
Just for future reference, I've managed to fill both NA8 and NB8A 5 speeds with 2 qts of Redline each.
Postby 93_Clubman » Sat May 18, 2019 5:17 pm
Similarly, my NA8 5 speed was filled by 2 quarts of Redline & Torsen 1 diff by 1 quart of Redline.
madmort
Postby madmort » Sat May 18, 2019 7:55 pm
magna_blue and 93_clubman Thanks. Did you notice any improvement in gearbox gear selection/feel with Redline?
1600Dave
Postby 1600Dave » Sat May 18, 2019 10:33 pm
You learn something new every day.
I'm still getting over the joy of recently discovering diesel oil now comes in 7L bottles, no more having piles of random 10L drums scattered throughout the shed, all with 3L left over from every oil change on the Hilux
Postby 93_Clubman » Sun May 19, 2019 11:52 am
madmort wrote:Did you notice any improvement in gearbox gear selection/feel with Redline?
Did it back in 2006, so car had only done 50k kms, & GB was fine & remained fine. What I did notice recently when clutch was replaced & the mechanic drained the Redline GB & diff oil (without being asked), was that gear selection is not as good cold with the run of the mill Penrite he put in.
RS2000
Postby RS2000 » Sun May 19, 2019 8:08 pm
I've found the new Penrite Pro Gear GL4 better than the Redline MT90 in my 6 speed.
https://penriteoil.com.au/applications/car-4wd/gear-oils/pro-gear-gl-4-75w-90#/
Users browsing this forum: No registered users and 82 guests
