Red_Bullet wrote:[... hopefully the ECU is capable of switching the higher current without blowing up the output transistors inside the ECU.
Relay. On my PS100 at least.
greenMachine wrote:Red_Bullet wrote:[... hopefully the ECU is capable of switching the higher current without blowing up the output transistors inside the ECU.
StanTheMan wrote:According to that sounds like the Bosh Yaris one is the ducks guts for us street Mx5
Red_Bullet wrote:Anybody got access to a Yaris and an oscilliscope? You could see what toyota engineers dwelled them at! Common figures around the internet though is 1.9 to 2.1 mS. If you dwell too long then the coil will saturate and overheat. (That's the nature of inductors in a DC circuit)
Magpie wrote:StanTheMan wrote:According to that sounds like the Bosh Yaris one is the ducks guts for us street Mx5
Have you managed to source these Bosh Yaris COP's that fit the MX5?
Hmmmm I may have suggested that a few posts ago...StanTheMan wrote:It turns out my wiring was dodgy.
Magpie wrote:Bosch 503 Coils suit Toyota from https://www.efisolutions.com.au/
Also make sure the spark plugs you are using have RESISTORS as these COPS highly susceptible to back feeding from non-resistor plugs... blows the transistor inside.
There are plugs without resistors that fit the MX5, any 14mm with threadreach of 19mm.hks_kansei wrote:I thought basically all plugs these days had resistors?
Magpie wrote:There are plugs without resistors that fit the MX5, any 14mm with threadreach of 19mm.hks_kansei wrote:I thought basically all plugs these days had resistors?
hks_kansei wrote:Would there be any reason to specifically use non-resistor plugs? (in an MX5)
Users browsing this forum: No registered users and 102 guests
