MX5 NC Dash Board Rattles
RR
Postby RR » Thu Mar 28, 2019 11:36 am
Hi Guys,
Trying to find out if any one has had this issue other than whats been put up on other forums. I've got a rattle sound coming from inside the dash that sounds like something rolling around or at times swing around inside the dash. NO Its not a lost baby rattler or a lose bolt from the sun visor over. If you can make any other suggestions that would great, i can only assume that it may be a lose screw from the vents in behind the crash pad of something inside the vent pipes ?
Re: MX5 NC Dash Board Rattles
Postby 93_Clubman » Fri Mar 29, 2019 3:29 pm
Might be worth checking the NC section of the Mazda Technical Service Bulletins in case it's been documented including a fix: https://www.miata.net/garage/tsb/
RR
Postby RR » Fri Mar 29, 2019 11:32 pm
Thanks for that, from what I gathered it could the audio brackets. I had removed thr radio to install a Bluetooth hands free module via the cd Straker socket. Blue tooth works fine but this could be a delayed legacy.
JBT
Postby JBT » Sat Mar 30, 2019 9:58 am
If the rattle started after the Bluetooth addition, then that's most likely the place to re-visit.
minipete
Postby minipete » Sun Mar 01, 2020 3:58 pm
Did you ever find the rattle?
I have exactly the same rattle and I recently (2 months ago) installed a new head unit.
minipete
Postby minipete » Tue Mar 03, 2020 12:16 am
Found my rattle.
A T40 Torx screw in the header came out and was rattling around in the sun visor.
One of my friends puleed down the visor and it fell out.
Happy days.
Pete
