What's happened to my engine?
Inksta
Re: What's happened to my engine?
Postby Inksta » Wed Jan 16, 2019 10:59 pm
No fuel pressure issues, though I agree that it would be nice to know why so much carbon. The engine has always run well, no real troubles at all. It had gradually started using a fair amount of oil (maybe 2 litres disappeared between each 10,000k oil change) - but virtually no smoke out the exhaust, and I put it down to leaky seals.
It's dríven daily and the engine has around 250,000 kilometres on it.
As you suggested, there's no discernible notching on the cylinders, so that's a plus.
Inksta
Postby Inksta » Fri Feb 01, 2019 9:13 am
Things looking a little healthier in this shot!
Waiting on rings and bearings to arrive, then the rebuild starts.
Also, I spoke to the machine shop about the carbon - they thought that it wasn't caused by any particular failure, just the result of a high km engine and slow commutes to work. Need to drive it harder more often :)
StanTheMan
Postby StanTheMan » Fri Feb 01, 2019 10:33 am
how much did you have your deck shaved by?
check protrusion of pistons.
check thickness of head gasket.
when engine warms up parts will expand and also stretch a little at high RPM.
I dont recall what the minimum clearance is any more. just check it though
Ive had my pistons hit the head with a slightly thinner head gasket at 3500 rpm upwards . worked fine with a standard size.
I'm talking about my Old B6 motor....
Inksta
Postby Inksta » Fri Feb 01, 2019 2:07 pm
Thanks Stan, good point - I'll watch out for that. Going to be using OEM head gasket.
Postby hks_kansei » Fri Feb 01, 2019 2:39 pm
Unless you specifically asked the machine shop to mill it down a lot, or the head/block had a really deep gouge, it wont be an issue.
To start having issues with pistons and valves etc you're looking at having them mill off whole millimetres.
A skim, which is what pretty much every machine shop will do unless specifically asked to to otherwise, is tenths of a millimetre.
And also assuming you're using OEM spec pistons, and havent gone for high comp ones or something.
StanTheMan
Postby StanTheMan » Fri Feb 01, 2019 2:49 pm
mmmm Id still tread carefully & check tolerances
My B6 motor had standard pistons which protrude 0.4mm above deck. and that is nothing unusual for B6's. My NB motor didn't protrude out like my B6
I went from a 1.3 standard head gasket to a 0.9mm for extra compression. it was too much. My pistons started hitting the head. Valves were fine.
Inksta
Postby Inksta » Sun Feb 03, 2019 8:55 pm
Yep they took off four thousandths of an inch (~0.1mm).
I'll keep an eye on it just in case.
Inksta
Postby Inksta » Sun Mar 10, 2019 9:04 pm
Just a little follow-up to finish this story.
Started it up last weekend, set the timing and went for a test drive. Touch wood, all good so far. Feels like a new engine. Pretty satisfying to have finished the job without any major dramas.
New bearings, rings, clutch, engine mounts, basic head job etc. - this "timing belt job" ended up more time consuming and more expensive than I had anticipated, but on the other hand I've got a car that feels young again, and learned a lot.
Thanks for all the help and advice. It's good to be back in the 5!
Inksta
Postby Inksta » Sun Mar 10, 2019 9:21 pm
Bonus shot of engine going back in:
Red_Bullet
Vehicle: NA8 - Supercharged
Postby Red_Bullet » Mon Mar 11, 2019 6:58 am
Well done mate. There's something really satisfying doing stuff yourself and learning learning learning along the way. :D
StanTheMan
Postby StanTheMan » Mon Mar 11, 2019 10:07 am
Did you work out why your engine was getting stuck?
Inksta
Postby Inksta » Mon Mar 11, 2019 6:50 pm
The fouling was being caused by excessive carbon build up. There was a good couple of millimetres of junk on top of the piston, and my theory is that when the car sat for a couple of weeks while I did the timing belt, some of it shifted - so it became a problem suddenly. You can see some spots (eg the flat bit at 12 o'clock) where the carbon was compressing against the roof of the cylinder:
Thankfully no damage done in terms of bent valves etc.
