AGI Rollbar fitting issues?
simie2014
Postby simie2014 » Sun Jan 27, 2019 11:48 pm
Hi folks. Everytime ive come on here for advice everyone has been very helpful...
I have a 4 post AGI rollbar that i am having difficulties with. The legs at the front have 100mm bolts going from top to bottom screwing into a plate on the underside of the car. The issue is there is a second (hidden) panal that is curved that has to be drilled thru' after.the first initial hole has been drilled. I am having trouble drilling the hole as the drill kicks sideways because of the curve to vertical in the panel.
Has anyone fitted one and had similar problem and how.was.the fix made to drill that hole. Help appreciated.
simie2014
Re: AGI Rollbar fitting issues?
Postby simie2014 » Mon Jan 28, 2019 6:19 pm
No worries. Fixed it.
