I'm recreating the stickers from the SP with the help of a graphic designer. I'm being very pedantic and they will be as close to the originals as is possible. Below is the current progress. The colours may look off but that is because metallic finishes are part of the sticker and not the colours in illustrator.
The wreath is still a WIP
Most of the SPs have had the gearknob replaced due to wear, tarnishing and the shift pattern sticker yellowing. The first of the stickers I'll be getting made will be the shift pattern. I know many of you have replaced the knob and gotten the more modern metallic shift pattern sticker with it but if you would like to have the original shift pattern let me know.
The other images will still be a while before I get stickers that I can share out, but if you're interested let me know. Because they're all metallic I need to find someone who can print the correct colours.
