mx5: drives like it's on rails?
guitarman
Postby guitarman » Sun Jan 06, 2019 10:46 am
Hello all!
I have often read on the internet that people say mx5 drives like it's on rails. What do they really mean by that? is it to refer minimal body roll?
Re: mx5: drives like it's on rails?
Postby NitroDann » Sun Jan 06, 2019 10:58 am
Stock ones have plenty of body roll, its about speed of response to inputs and razor sharp accuracy, even in flogged out 25 year old form.
It's a bit like riding a bmx bike, you and the vehicle are one, and every input is met by an accurate and immediate response.
Postby Magpie » Sun Jan 06, 2019 10:59 am
Refers to a car the feels fast but is in fact slow....
Rocky
Concerned Citizen.
Postby Rocky » Sun Jan 06, 2019 1:03 pm
A bit of a nonsensical phrase really, as no matter how good handling the vehicle it still requires a driver that is capable of the correct inputs.
e.g. - There is a windy mountain road that I occasionally drive and the MX5 handles beautifully WHEN I get it together. Bad lines and wrong speed/gear still produce a ragged result just as they would in a Toyota Hi Ace.
Nothing is "unstickable" given bad inputs.
JBT
Postby JBT » Sun Jan 06, 2019 7:00 pm
guitarman wrote:..people say mx5 drives like it's on rails. What do they really mean by that? is it to refer minimal body roll?
It refers to its grip in corners, which can be tenacious or limpet like....given decent tyres and driver. 8)
They also say that the gear change is "rifle bolt" (action) precise. If you've used a bolt action rifle, you'll know. :D
Wolfgang
Postby Wolfgang » Sun Jan 06, 2019 7:31 pm
JBT wrote:It refers to its grip in corners, which can be tenacious or limpet like....given decent tyres and driver. 8)
And proper alignment.
Rocky
Concerned Citizen.
Postby Rocky » Sun Jan 06, 2019 9:13 pm
JBT wrote:They also say that the gear change is "rifle bolt" (action) precise. If you've used a bolt action rifle, you'll know. :D
I have never understood the "rifle bolt" description of the MX5 gearchange.
To me it is a reasonably competent gearshift but certainly not close to the best I have experienced.
Front engine rear-wheel drive FIATS and Alfas of the '70s had that distinction.
Postby Lokiel » Sun Jan 06, 2019 10:07 pm
The original 5 speed gearboxes in the NA are highly regarded for their feel - in one of Mark Hammond's TopGear episodes on the NA he claimed it's one of the 5 best gearboxes of all time (that number seems quite apt).
The NB 6 speeds use the Aisin gearbox which is a piece of crap - even the NCs and latest 86's have issues with it.
Miata Roadster tall-angled SSK helps a LOT though.
To me, the phrase "Handles like it's on rails" means that the car doesn't lose grip when you "fang it" through "the twisty stuff" (unless you f-it up).
JBT
Postby JBT » Sun Jan 06, 2019 10:19 pm
Yeah, the NA gearbox was ex 929 with modified linkages and worked beautifully.
I think the NC gear shift is excellent but the NB 6 speed was woeful.
guitarman
Postby guitarman » Sun Jan 06, 2019 10:30 pm
What is/are the best gearboxe/s that you have experienced?
Postby Danny » Sun Jan 06, 2019 10:36 pm
S2000 Honda.
Rocky
Concerned Citizen.
Postby Rocky » Sun Jan 06, 2019 10:38 pm
As I said above, the 5 speed gearbox in the FIAT 124 Sport Coupe is probably the best I have experienced, and then maybe the gearbox in the Alfa 1750 GTV.
ralt
Postby ralt » Sun Jan 06, 2019 10:58 pm
Hi.
The best I have experienced was the Lotus cortina ultra close gear set.
Postby 93_Clubman » Mon Jan 07, 2019 7:53 am
105 Series was good, apart from weak second gear synchro, but NA6 was better, then again Elan was probably even better, certainly a shorter throw.
Postby hks_kansei » Mon Jan 07, 2019 11:39 am
I loved the 5 speed on the Mazda B2200 I rented when I moved house once.
it was hilariously worn, the play the stick had IN GEAR was more than the MX5 sticks entire range of movement when shifting.
It was an amazing piece of synchro crunching, bearing whining, floppy sticked harmony.
On a more serious note, the box in my old RWD 626 felt pretty good too, but I think that may have actually been an early iteration of what eventually became the MX5 5 speed.
