Speed's boosted NA6
- ManiacLachy
- Engaged
- Gladiator
Re: Speed's boosted NA6
3gress wrote:Good to see you back mate.
ManiacLachy wrote:Welcome back, Speed!
Same from me. Welcome back!!
- Alex 2550
been a while for me as well mate, good to see you back!!
Retro NA8
build viewtopic.php?f=57&t=71923
- shirtz
like the bonnet. interested to see how the flaps are welded att he sides.
as for the intake pics, cheers, but ive already cut the big hole lol. hp gain minimal at best
- Cus
welcome back indeed!
I like where you're going with the headlight cover, add some some crafty airbox crafting and you should get decent air whenever you're moving
Cherrs bro. Actually works a treat and the sound from my JR filter is amazeballs!Cus wrote:welcome back indeed!
Sent from my SM-G960F using Tapatalk
Ok so a bit has happened lately..
I hosted a dodgy day last Thursday and a few of us (STM, Bear2330, two40, Jason G and Jason H) pulled the tired motor and box from car. I'd already removed the head so the process was farely simple.
We then went about separating the motor and box that I'd recently purchased from mania, fitted my xtreme clutch and bolted on the exhaust manifold, RX8 injectors, alternator, belts etc.
Then on another day my nephew and I fitted a new Bosch clutch slave, mazda speed engine mounts (both mine were broken!), added my plated cam cover. Then I cleaned the absolute bejeezus out of it, whilst my nephew cleaned the tranny tunnel and bottom half of the engine bay, then we set about fitting the motor and box.
She now looks like this...
(Oh wait, I've forgotten how to add pics in tapatalk...)
As below...
Here's my nephew happy to help and learning about cars...
The motor as purchased from Mania. I've never seen such a clean motor inside!
Apparently belonged to a club member who took great care of it and serviced to date... the cam cover, cams are mint!
The ute I borrowed. Oh yeah and I left the legal industry and am now a plumber.
We had a bit of a miscommunication on the dodgy day and unfortunately my clutch plate was installed back to front.
I only realised when I went to test drive the car with the new motor... couldn't engage any gear whilst the engine was running as the plate was jammed on the flywheel.
So STM came round today and we both ripped in, dropped the box, pulled the clutch, inspected, cleaned and refit in the correct orientation. So much harder whilst the gearbox was in the car but what do you do..
Here we are both doing our first gearbox pull on a mx5... as STM later corrects me he has done clutches before. I'd never done either on a mx5.
STM really is the man. So grateful for the extra pair of hands.. and socket extensions! Lol
Now she needs a wash. I'm also not getting full throttle so will recalibrate the TPS, adjust the accelerator cable and also want to re adjust the clutch pedal to centre the travel. So happy to have my baby back on the road again
- StanTheMan
Seriously Speed, I was regretting volunteering when I found out we were going to pull the box only....
I really didn’t think at around lunch time wed finish this ..... ever. Let alone today. Starting was slow. But once momentum was gained. We finished.
Great work. 1st time I pulled a gearbox only on an MX5 . But not my first clutch job by any means.
We nailed it! Maybe we should have had that bourbon first thingStanTheMan wrote:Seriously Speed, I was regretting volunteering when I found out we were going to pull the box only....
Great to hear she is up and running again, you have to be proud of what you have achieved. I'm happy that my small contribution got her back on the road that little bit sooner.
