Bumpstops
Bumpstops
While I can’t find my post on bumpstops I know Kevgoat Will be interested in this pic of my rear bumpstops which I replaced this morning with fat cats. If this is what can happen to OEM after 50000 I’m not concerned about the fmc’s longevity.
No wonder I was complaining about the SE’s ride!
NB SE, NA 1.8.
Re: Bumpstops
Wow, and I thought my old ones were bad!
At least mine were in one piece after ~160,000km, granted the rears had big splits down the sides, and the centre hole was flogged out.
weirdly, I cant find your old thread either.
Odd since I remember posting in it. Must just be the forum server having a fit and losing the odd thread.
- KevGoat
Re: Bumpstops
Holy moly that's crazy! Mine were also about 50,000 kms when I changed them out but they still seemed fine. Probably an indication of how much more your car is "properly dríven" than mine
Re: Bumpstops
Someone explain what I'm looking at? It looks like two piles of dirt.
Re: Bumpstops
bruce wrote:Someone explain what I'm looking at? It looks like two piles of dirt.
Crumbled bump stops.
The NB ones were a high density foam, unlike the rubber of the NA ones.
And yeah, these ones haven't fared too well, and have crumbled into high density dust.
Re: Bumpstops
Owned by “a little old lady” who drove it from Brisbane to Toowoomba regularly...just pulled the front ones - left hand side front has started to crumble. In the SE the front ones are yellow white and the rears pink.
NB SE, NA 1.8.
Re: Bumpstops
Standard NB are the same, rears a pink/red, fronts on mine were white, but they may have just faded.
Re: Bumpstops
Its a bit odd - I would have guessed bump stops being moulded products - rubber or even plastic injection moulded- machining is not what you would expect for an OEM volume item. Foam products you would not expect to be used in a "shock" application.
Re: Bumpstops
Mr Morlock wrote:Its a bit odd - I would have guessed bump stops being moulded products - rubber or even plastic injection moulded- machining is not what you would expect for an OEM volume item. Foam products you would not expect to be used in a "shock" application.
I agree that it's an odd choice.
especially since the foam (which is probably a foam rubber) isn't particularly dense or resistant to compression, you can squeeze them almost flat by hand.
Here's a diagram that shows the NA on the left, and the NB setup on the right.
The shock rod passes through a pair of rubber donut shaped bushes that sandwhich the top-hat (the ones with the left leaning strokes in the image)
I suspect these may form the final limit of the bump stop, being the last piece to stop the shock bottoming out in it's body.
Re: Bumpstops
Foam bump stops work far better than rubber ones, because it foam is more progressive and compresses down more (meaning that they take away less shock travel).
Failure like this is usually due to exposure to UV and/or age, rather than usage.
Re: Bumpstops
Spac wrote:Foam bump stops work far better than rubber ones, because it foam is more progressive and compresses down more (meaning that they take away less shock travel).
True, but the purpose of a bump stop is to halt movement before either the shock bottoms out and damages itself, or before spring bind.
Bump stops are supposed to take away a little bit of shock travel, to prevent the shock piston from trying to punch itself out the bottom of the body.
Re: Bumpstops
This is the quandary. The MX5 was designed, at least in the case of the NA for the bumpstops to be an integral part of the suspension hence the low spring rates. The bump stops ADD to the spring rate and effectively give a progressive spring rate.
Hence when people go to 9/6 coilovers they complain because of a harsh ride.
In my case I had 4-5mm of bump travel before the bumpstops engaged on the rear
For a track car the bump stops should only limit the extremes of damper movement. Personally I would argue that any car should have bumpstops that limit extremes not add to the spring rate!
Re: Bumpstops
Of course, but a foam one can do its job and be fully compressed to (say) 10mm, rather than 30mm, then your whole shock can be 20mm shorter.
In reality, a rubber bump stop has to be very long to give the same progression a correctly specced foam one.
The late John Wills had a wall covered in tubs of bump stops, of varying lengths, shapes and durometers - there's a lot more to bump stops than "they should make them out of rubber"!
Users browsing this forum: No registered users and 168 guests
