In general more negative camber in the front than the rear.
Whilst the amount of toe in will give you high speed stability it will impact turn in. You could run toe out front and toe in rear.
Try 3.5 neg front, 3.0 neg rear and zero toes. Maybe toe out front. Be aware toe will impact tire wear! Look at your tyre temps and adjust the alignment/pressures accordingly.
Who did the alignment in Brisbane?
Thanks Magpie
The a full day at the last sprints at LS has shown noticeable inner tyre wear due to the toe in, the front left also had a camber bolt, ill give accurate a try next week and drop the rear camber back a bit, best I can get out of the front is -2.00 camber at the sacrifice of bit of caster
in saying that the car felt balance and previous under steer was gone although the ado8r have stiff side walls and I have them running at 26psi cold
