david_syd_au wrote:As a discussion starter, here is my list re adding a turbo to a my 2012 NC2 PRHT.
Must
- Produce at least 160 kW atw
Easy
- Boost is controlled to avoid damage or abnormal wear to engine internals and drivetrain, under normal road use
Easy
- Retain all current features, ie air-con, power-steer, ABS, traction & stability control
MS3 plug and play runs all of that
- Retain the stock ECU hardware
If you mean sensors and alternator etc, yep that too
- Other than additional available performance, must drive and idle like stock, and not overheat in stop-start of highway situations.
It will certainly have a new personality, like how a V6 camry and a V6 commodore have a different personality, but it will be as good.
- Be legal for registration and insurance in NSW
Easy
- Externally discrete installation (eg intercooler not obvious), and of course no "whoosh whoosh" noises!
You will definately hear something, but keeping it sensible like an OEM turbo car is easy.
- Job has a price limit, based on agreed assumptions of vehicle condition and parts & labour costs (eg engine internals are ok, turbo costs $x, manifold requires x hours to make). I must avoid blowouts due to unanticipated issues with fabrication or compliancing.
Unavoidable in every last case, if it was found that your car needed maintenance then that work would need to be done and paid for. For example.
Desirable
- In-car power adjustment or tune switching
Completely useless, we are in the future now and the throttle is made for this job, but it can be added.
Bonus
- Additional EC functions, eg flat-shifting
If you want racecar stuff you can have it, all costs money though.
- Boost display
Fit any gauge you want after the build is done.
It is likely you will have a different list, as we all want different things from our cars.
My NC is a daily driver for my wife and I and it has to be reliable and safe to drive for both of us in variable conditions. We don't need max power or want to drive like idiots, we have an MX-5 race car for that :-)
Anyway, this is my starting point.
NitroDann wrote:Easier for me, no difference for you
Custardtart wrote:This looks a good RHD kit and BBR have a solid reputation for quality.
https://www.mx5oc.co.uk/forum/yaf_posts ... stall.aspx
Snowmotion wrote:Custardtart wrote:This looks a good RHD kit and BBR have a solid reputation for quality.
Looks good but that is a lump of money.
NitroDann wrote:I have a bbr stage2 nc at work.
Its pretty bloody average. Caught on fire first track day and leaked everywhere and everything.
Im 'finishing' it.
