Watching as I may need to go down this path, but keeping it NA...Custardtart wrote:keeping it simple and low cost
2.5 swap lets talk cams
Re: 2.5 swap lets talk cams
- Custardtart
Magpie wrote:Watching as I may need to go down this path, but keeping it NA...Custardtart wrote:keeping it simple and low cost
If I was going N/A I'd keep the 2.5 head, go race cams and make sure the intake is port matched to take maximum advantage.
NC1 - 2.5 opposite lock device
Lakeside 62.3
Lakeside 62.3
- StanTheMan
What sort of compression do you NC guys have?
Sent from my SM-G935F using Tapatalk
- Custardtart
StanTheMan wrote:What sort of compression do you NC guys have?
Standard CR for the 2.0l engine is 10.8:1. Not much to be gained from trying to increase it tbh
Lakeside 62.3
Lakeside 62.3
- StanTheMan
Is that 2.5 l similar to the current 2.5L out if the mazda 3?
- Vehicle: Non MX-5
No. The MZR engines are different from the skyactiv engines.
Ford still use some MZR engines in their models. But MAzda is all Skyactiv nowadays.
Users browsing this forum: No registered users and 39 guests
