Any legally registered MX5 LS V8s in Australia?
Re: Any legally registered MX5 LS V8s in Australia?
Postby bruce » Sat Nov 03, 2018 9:14 am
Nevyn72 wrote:From what I have found the NC PRHT comes in at ~1207kg so under NCOP can have a LS1 or 'small' LS3 up to ~6.0L capacity naturally aspirated.
Has anyone got an accurate figure for the RF ND?
The best I can find is 1104kg so just into level 3 or up to ~5.5L capacity NA, still not quite enough for a 5.7L LS1...... :|
Interesting. Why aren't there more v8 NCs? Maybe the 1200kg weight is questionable.
Regards NDs, u can get a 5.3 litre LS in the US, so import one of those.
Postby manga_blue » Sat Nov 03, 2018 10:14 am
bruce wrote:I purchased mine done but not engineered (which I did). Thus I know all about engineering.
So is yours Warwick Gates' old car? I was wondering what happened to that one.
Postby bruce » Sat Nov 03, 2018 11:05 am
Not Warwick's (was that the grey Typhoon WA car?)
I know of 3 on the road; WA car, Qld car and mine.
Postby manga_blue » Sat Nov 03, 2018 12:40 pm
I can't remember what colour it was when it won the Dutton. The last time I saw it was about 10 years ago when it was living in Melbourne and it was red.
Postby bruce » Sat Nov 03, 2018 8:16 pm
Mine is red but it hasn't run Dutton. I thought the Perth one was grey and Qld one was blue. There aren't many around.
mossy
Postby mossy » Thu Nov 15, 2018 9:45 am
According to this the NC is 1179 kg. Not sure if this is the heaviest version fully optioned or not but if you can get it to 1200 kg you should be able to get a 6.0 LS in there. Also as far as I'm aware the engine has to be of the same year as the donor car or newer.
http://australiancar.reviews/_pdfs/Mazd ... 201401.pdf
Postby bruce » Thu Nov 15, 2018 10:41 am
Yup, aware of these things. Problem is, not a lot of Engineers will sign off on such a swap.
mossy
Postby mossy » Thu Nov 15, 2018 11:02 am
Try Paul Bottomly or Bill Malkoutzis.
You just need to do it Bruce so I can see if its worthwhile for me to do down the track :lol: I'll even stop by to lend a hand :mrgreen:
Postby bruce » Thu Nov 15, 2018 11:55 am
No, you do it, so I can buy it for peanuts a few years down the track.
I'm not silly enough to spend bulk money on pioneering the swap.
mossy
Postby mossy » Thu Nov 15, 2018 12:58 pm
:lol: I think to do the swap and for it to not cost a fortune you would aquire a well priced NC with some mods to sell off all the parts and also buy a full donor commodore from the auctions to basically wreck yourself. I think it would still be an expensive proposition.
Another engine option for a v8 would be a coyote V8, at 5.0 it would easily meet the weight/displacement requirement. It definetely sounds better too although I think no one has attempted a coyote swap before.
https://www.youtube.com/watch?v=SjeKSumjcRA&t=454s
pie5
Postby pie5 » Thu Nov 15, 2018 5:00 pm
mossy wrote:Another engine option for a v8 would be a coyote V8, at 5.0 it would easily meet the weight/displacement requirement.
Have you seen the size of the coyote V8. :!:
There is no way that goes close to fitting a MX-5 engine bay. :lol:
2019 Racing Orange 30AE #783
2006 Stormy Blue NC 2.4 GWR Header & Exhaust, Progress Springs, Koni Shocks, Whiteline Sways, Recaros.
mossy
Postby mossy » Thu Nov 15, 2018 5:11 pm
There was a thread on miata.net where someone said they looked into it but there was a problem where the water and oil lines come out on the left side as they take up the space the steering is located, but our steering in on the right so maybe there would be a chance :P
trickytrev
Vehicle: NC - Supercharged
Postby trickytrev » Thu Nov 15, 2018 7:42 pm
Tom at Bullet did a NC LS1 late last year or early this year, by memory QLD max cc was 5800 so LS1 just came in under that so QLD yes NSW NOOOOOOO.All to do with power to weight which im guessing every one knows
Blown 300+
Postby bruce » Thu Nov 15, 2018 7:55 pm
Yes, that might be another twist - we know about capacity to weight, but Engineers might consider power to weight.
Forget a Coyote, it's not any easy fit/does not fit, plus a used engine will be pricier than an LS. Remember the thread of the guy in Qld who reckoned he was going to fit a Coyote into an NB. He then posted a picture of an old Windsor (the engine would be older than the chassis which is a no-no).
mossy
Postby mossy » Fri Nov 16, 2018 10:12 am
I think power to weight should be fine in an NC. One of our 240z club members recently had his 240z engineered with a BMW E36 M3 motor, 240z are around 1040 kg's and the 3.2 M3 motor is around 320 hp I think.
