High revs
Bloggsy
High revs
Postby Bloggsy » Mon Nov 12, 2018 9:40 am
Looked at an ND for the first time and when started from cold it was running on high revs with a green thermometer icon on the dash. The owner said that this is normal and revs drop back when the icon goes out. My question is Is this normal?
Re: High revs
Postby hks_kansei » Mon Nov 12, 2018 9:44 am
how high revs are you talking?
for most cars (cant say specifically for the ND) they'll idle a few hundred rpm higher until warmed up.
But if it's starting then revving to 2k it's probably got an issue.
Bloggsy
Re: High revs
Postby Bloggsy » Mon Nov 12, 2018 9:54 am
I would have to check but is the green icon normal?
project.r.racing
Re: High revs
Postby project.r.racing » Mon Nov 12, 2018 8:06 pm
google "mx5 nd owner manual" and start reading. i'm sure you'll find the answer quicker than awaiting a response on a forum.
greenMachine
Re: High revs
Postby greenMachine » Mon Nov 12, 2018 8:36 pm
Wash your mouth out PRR :roll:
Read the manual indeed, whoever heard of such a thing ... :| . Next thing you will be telling people about the search function - way to get a ban :cry:
:mrgreen:
OMY005
Re: High revs
Postby OMY005 » Tue Nov 13, 2018 11:54 am
Bloggsy wrote: My question is Is this normal?
Yep, normal behavior.
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
Bloggsy
Re: High revs
Postby Bloggsy » Tue Nov 13, 2018 2:15 pm
Excellent thank you for the reply
Roadrunner
coyotes after you
Re: High revs
Postby Roadrunner » Wed Nov 14, 2018 12:40 pm
Yep it's normal and usually sounds horrible too for the 60 seconds it takes to warm up.
My CX5 Diesel does the same thing.
MeepMeep
Re: High revs
Postby bruce » Wed Nov 14, 2018 12:57 pm
When does a diesel sound good?! Ha!
StanTheMan
Re: High revs
Postby StanTheMan » Wed Nov 14, 2018 6:12 pm
Diesel should be banned for private use
Sent from my SM-G935F using Tapatalk
StanTheMan
Re: High revs
Postby StanTheMan » Wed Nov 14, 2018 6:13 pm
But then
Why should business get all the benfit?
Roadrunner
coyotes after you
Re: High revs
Postby Roadrunner » Wed Nov 14, 2018 8:31 pm
I was just saying my ND also does the high rev thing on warm up, as does my CX5 (and almost all modern cars).
And I'll take my Diesel CX5 for towing my track MX-5 between 2-5 hours down the highway once a month any day over a petrol version thanks :|
MeepMeep
project.r.racing
Re: High revs
Postby project.r.racing » Thu Nov 15, 2018 7:42 am
bruce wrote:When does a diesel sound good?! Ha!
When it is turned off. :D
