Hopefully you will rebound from the excitementCustardtart wrote:Quite excited today ......
Custard’s Tart
Re: Custard’s Tart
Re: Custard’s Tart
That joke was shocking, but I don't want to dampen your spirits
Re: Custard’s Tart
Okibi wrote:That joke was shocking, but I don't want to dampen your spirits
I'm sure you will rebound and bounce back.
- JBT
Re: Custard’s Tart
Magpie wrote:Okibi wrote:That joke was shocking, but I don't want to dampen your spirits
Any other advice that springs to mind?
Re: Custard’s Tart
Well it might take a bit of adjustment and I don't want to give a bump steer but shouldn't be long before he's upright and staying positive.
Re: Custard’s Tart
A little too soft, a little too hard, aaah just right.
- Wombit
Re: Custard’s Tart
I wonder what the next joke will be? The suspense is killing me!
- Custardtart
Re: Custard’s Tart
Sorry to put a dampener on proceedings but I needed to spring to it!
Had to cut a hole in the engine/firewall brace and use. 3mm allen key for adjustment. Probably a good excuse for a cusco brace
Rear adjusters need a bit of tidying.
Car sits lower bit not slammed, a little bit higher than legal minimum. I rolled the arches but these 9” rims comfortably fit now with the extra camber.
This alignment is a bit lower I’ve been able to get a fair bit more camber and also a degree of toe out. This has transformed the front end steering feel, much more weight, zero dead spot and less sensitive on turn in. I love it so far!
I’m going to do a 3 hour road trip tomorrow so will be able to form a better view then and of course it’s the Noosa Hillclimb this weekend but so far the car is much firmer, the ride is a fair bit harsher but I reckon it’s acceptable although Mrs Tart will have the final say! If I was purely after a fun road set up I’d go Bilstein/Eibachs, they’re awesome.
NC1 - 2.5 opposite lock device
Lakeside 62.3
Lakeside 62.3
Re: Custard’s Tart
Enjoy, is a fun course. I contemplated going but car will not be ready, however will be heading up the Landsborough to pick up my dampers and fitting them on Sunday. Yes I will have MCA suspension fitted...Custardtart wrote:Noosa Hillclimb
Re: Custard’s Tart
I look forward to hear your impressions of the new set up.
- Custardtart
Re: Custard’s Tart
Aw crap, got about 30 mins into the planned drive today and the car overheated. It's at the local garage now being looked at as I don't have time between now and Friday's leaving time for Noosa.
I suspect it's either thermostat or cracked reservoir. I noticed the AC was behaving erratically just before so possibly a fan issue also.
On the plus side, wow oh wow does this new set up grip! On the few corners I got round up Mt Glorious I was nowhere near the limits.
Lakeside 62.3
Lakeside 62.3
- Regie
- Vehicle: NC - V8
Re: Custard’s Tart
oh bummer to hear about the engine mishap.
did you loose coolant? if the reservoir tank is cracked it will be pretty noticeable around where the cap sits.
if the thermostat is stuffed it usually throws a code and will take ages to get to operating temp, have never heard of one that fails to open, they usually always fail to shut
Re: Custard’s Tart
Very hot in the South East of Queensland at the moment
Good thing about Noosa is the track is shaded most of the time, whilst this then gives hot/cold spot on the black stuff it is good for keeping cars a little cooler.
I trust the mechanic will find the cause and will make bump in on Friday.
- Custardtart
Re: Custard’s Tart
Regie wrote:did you loose coolant? if the reservoir tank is cracked it will be pretty noticeable around where the cap sits.
Coolant everywhere, didn’t notice anything obvious around the cap. The garage will test it for cracks and currently doing some diagnostics to see where the fault lies so fingers crossed I can get it sorted in time.
Lakeside 62.3
Lakeside 62.3
- Custardtart
Re: Custard’s Tart
Magpie wrote:Very hot in the South East of Queensland at the moment
Is there shade you n the paddock or would you recommend a sunshade?
Lakeside 62.3
Lakeside 62.3
Users browsing this forum: No registered users and 69 guests
