NC trackday coilovers
Custardtart
Re: NC trackday coilovers
Postby Custardtart » Fri Oct 26, 2018 7:01 pm
Quick update. I’ve ordered a set of MCA reds with 12/6 springs. Time will tell if this works both on track and for Mrs Tart!
NC1 - 2.5 opposite lock device
Lakeside 62.3
Snowmotion
Postby Snowmotion » Fri Oct 26, 2018 11:02 pm
She will love it. :)
Custardtart
Postby Custardtart » Sat Oct 27, 2018 11:08 am
Snowmotion wrote:She will love it. :)
Haha lets hope so! Will be interesting to see the times at Lakeside on 23rd Nov as the car will have had no other changes.
Lakeside 62.3
JBT
Postby JBT » Sat Oct 27, 2018 1:24 pm
FWIW, I put MCA Street Essentials on our 135i and they transformed it. Mrs JBT reckons they're good too.
Custardtart
Postby Custardtart » Sat Oct 27, 2018 9:41 pm
JBT wrote:FWIW, I put MCA Street Essentials on our 135i and they transformed it. Mrs JBT reckons they're good too.
Good to hear :D
Lakeside 62.3
Tony
Postby Tony » Tue Dec 04, 2018 6:24 pm
Custardtart wrote:Quick update. I’ve ordered a set of MCA reds with 12/6 springs. Time will tell if this works both on track and for Mrs Tart!
Do you have any feedback on the Reds with the 12/6 combo as a dual purpose set up?
'09 NC2
Custardtart
Postby Custardtart » Tue Dec 04, 2018 7:08 pm
Yep sure.
I was told by MCA there wouldn’t be any settling in and on the first two drives I found the ride a fair bit harsher than the Bilstein/Eibachs.
However, I then did a couple of 2 hour drives and a track day and found the harshness really went away.
The main difference now is only felt on rougher sections and bigger potholes and cracks where the car does crash a fair bit more.
My wife daily drives the car and hasn’t noticed any difference!
Honestly, if it was a pure road car or saw limited track use with a novice driver I’d say the Bilstein/Eibach set up is a fair bit nicer, you can add the RX8 sway bars to give a very sporty feel all without anywhere near the cost.
The Reds are different class at 8 tenths plus on a track though so if you’re serious about track work I’d recommend them.
Happy to be more specific
Lakeside 62.3
Tony
Postby Tony » Tue Dec 04, 2018 7:16 pm
Fantastic; thanks...
'09 NC2
project.r.racing
Postby project.r.racing » Wed Dec 05, 2018 6:50 am
You probably just got used to the bumps. Going from a softly sprung car to a stiffer sprung car, you'll always notice the difference. But ride in the stiffly sprung car enough, and you'll somehow for get there is difference, or begin to think the difference is much smaller than you first thought.
Custardtart
Postby Custardtart » Wed Dec 05, 2018 1:19 pm
project.r.racing wrote:You probably just got used to the bumps. Going from a softly sprung car to a stiffer sprung car, you'll always notice the difference. But ride in the stiffly sprung car enough, and you'll somehow for get there is difference, or begin to think the difference is much smaller than you first thought.
Yeah, I did think this might be the case, no real way of knowing short of sticking the old stuff back on. I heard lots of feedback that the ride quality improved from people fitting Ohlins coilovers but their spring rates were too soft for full on track use (7/5 I believe) so I figured if the reds were unbearable I'd sell them and try the Ohlins but I can't see that happening now. I got some feedback on the 12/6 springs from a forum member that gave me enough confidence to give it a go.
Lakeside 62.3
JBT
Postby JBT » Wed Dec 05, 2018 4:08 pm
My Teins are 7/5 and felt appreciably stiffer than OE. However, they are now the new normal. :roll: Mind you, I could feel a two click softer damper difference.
Users browsing this forum: No registered users and 149 guests
