Penrite Synthetic Gearbox Oil
GR124
Vehicle: MX5 Locost
Re: Penrite Synthetic Gearbox Oil
Postby GR124 » Sun Oct 07, 2018 12:19 am
RS2000 wrote:GR, its 1999 NB8A which is the same as 2000.
Big thanks mate, I’ll run with the GL-5
JBT wrote:Nulon do a GL4 synthetic. I'm using that in the NC and it's fine.
Cheers JBT, this issue was the Penrite full synthetic oil I have purchased is GL-5. Looks like it will be fine.
Red_Bullet
Vehicle: NA8 - Supercharged
Postby Red_Bullet » Sun Oct 07, 2018 12:36 pm
Most of everything I've read recommend a GL4. Which is what I use, never tried a GL5 in it. Something to do with compatibility with synchro rings.
RS2000
Postby RS2000 » Sun Oct 07, 2018 6:18 pm
Postby Magpie » Sun Oct 07, 2018 6:25 pm
Wombit
Postby Wombit » Sun Oct 07, 2018 8:03 pm
Hey Magpie, what's your reason for posting this article?
Funnily enough, I came across this earlier today when looking into GL-4 and GL-5 oils, and am going to order the Penrite GL-4 oil tomorrow.
I'll be getting the full suite of fluids that I haven't yet changed recently, including diff, power steering, and brake fluid.
Postby Magpie » Sun Oct 07, 2018 8:25 pm
Was because people were asking the difference :)
Wombit
Postby Wombit » Sun Oct 07, 2018 8:49 pm
Cheers for that, that's what I thought.
The key point I took away from it was there's a higher level of sulphur/phosphorus additive in the GL-5, which disagrees with the bronze synchros in the 6-speed transmission, causing excessive wear.
RS2000
Postby RS2000 » Sun Oct 07, 2018 9:00 pm
I'd be interested to know if the NB8A owners manual lists GL5 as suitable for the gearbox, like the Mazda workshop manual does?
Postby manga_blue » Sun Oct 07, 2018 9:58 pm
My NA8 owners manual says both GL-4 and GL-5 oils are OK and, apart from a few changes to the turret and shift forks, it's the same 5 speed gearbox as the NB8A.
Postby manga_blue » Sun Oct 07, 2018 10:20 pm
manga_blue wrote:My NA8 owners manual says both GL-4 and GL-5 oils are OK and, apart from a few changes to the turret and shift forks, it's the same 5 speed gearbox as the NB8A.
Just found the page for the NB8A Owners Manual. It says the same thing: GL-4 and GL-5 are both ok. 75W-90
https://manuals.co/workshop/mazda/mx-5/2000-mazda-mx5-owners-manual/3275/252
RS2000
Postby RS2000 » Mon Oct 08, 2018 7:35 am
Many thanks for that manga.
So, there is a bit of contradiction at the bottom of page 5 in the article https://www.widman.biz/uploads/Transaxle_oil.pdf
He says follow the manual (for modern cars), then says GL5 is not suitable for synchro transmissions.
GR124
Vehicle: MX5 Locost
Postby GR124 » Mon Oct 08, 2018 8:33 am
Magpie I also found that write up as well during my google search.
I found this from Penrite as well https://www.penriteoil.com.au/assets/pd ... ential.pdf
I have already cracked open the bottle of Full Synthetic GL-5 so I'll be using it.
Red_Bullet
Postby Red_Bullet » Mon Oct 08, 2018 9:16 am
I think from memory it depends on what the synchro rings are made from. While GL5 or GL4 may both "work" I believe from what I have read that GL4 is preferable. When I got Automotive Plus to replace a broken gearbox for me they put martini extreme pressure 75/80 GL4 in it.
I have a 6 speed waiting for the next failure of the 5 speed and have some of the Motorcraft GL4 waiting ready to go in it.
GR124
Vehicle: MX5 Locost
Postby GR124 » Mon Oct 08, 2018 9:29 am
If I get a minute today I'll give Penrite a call. I'm guessing they wont have a hang over after the Bathurst result :roll: :frown:
Postby Magpie » Mon Oct 08, 2018 10:41 am
My concern is the cost of repair to the 6 speed box. Hence I will continue to run a GL-4 oil.
A second hand (unopened, unknown condition) costs over $1k (less than a hardtop at the moment) the OEM parts are VERY VERY EXPENSIVE and as Daffy found out the main shaft is made on demand...
Yes the Aisin 6 speed is used in other cars, but interchangeability information is very hard to come by :(
Users browsing this forum: No registered users and 75 guests
