Zac's NB8a
Re: Zac's NB8a
I reckon some round spotties would look better than the rectangles?
Re: Zac's NB8a
Purchased an adaptronic, rx8 injectors and a Koyo radiator
Does anyone know what sort of power the factory fuel pumps give up at? I’m only intending on running very low boost. Cheers
- StanTheMan
Re: Zac's NB8a
How much is a fuel pump?
Are the Rx8 injectors the real deal? Or are they the genuine fakes from Flea bay?
Personally id loose the adaptronic unless you know about it and very good at tuning it. SwAp it for a mS3 if you intend to self tune.
The charger.....nice!!!!
If you are self tunig. Definately invest in a wideband. Regardless of which ecu you decide to use
Those spotties wheels combo have a real 80s retro look to them.
80s are back. We must all grow our hair Jason Donavan style.
Sent from my SM-G935F using Tapatalk
Re: Zac's NB8a
Hey Stan, thanks for the reply!
I went with new old stock of adaptronic because "my" tuner was relatively happy with tuning it and I picked it up for $700. He's pretty experienced so hopefully it's no problems there. At that price I hope if it's not suitable I can on sell.
Spartan 2 wideband ordered
I see your point re fuel pump.
The rx8 injectors are real deal!
The charger will be a bit of a stuff around, it only came with mounting bracket and tensioners, I'll have to learn about setting up dummy throttle body?
80s never left
80s never left
Re: Zac's NB8a
dont mind another diary entry haha, took the car to wet track day, was great to learn to drive in a high grip, low power set up! I was quite rubbish, relying on handbrake and clutch significantly to link the track!
Adaptronic has arrived, purchasing wideband tomorrow. - Looking to source dummy throttle! can anyone give advice!
