Not boosting/ surging
Badbuzzard
Re: Not boosting/ surging
Postby Badbuzzard » Mon Sep 24, 2018 4:16 pm
Cheers very much guys, have to change it now as I broke one of those plastic barbs off. I do think the asco can be fitted better and looks neater but hey! I have the MAC so in it will go. Pictures make such a difference, to me anyway.
Badbuzzard
Postby Badbuzzard » Mon Sep 24, 2018 4:19 pm
Cheers very much guys, have to change it now as I broke one of those plastic barbs off. I do think the asco can be fitted better and looks neater but hey! I have the MAC so in it will go. Pictures make such a difference, to me anyway. One more question ManiacLauchy, did you cut down the filter to make it flush?
Badbuzzard
Postby Badbuzzard » Mon Sep 24, 2018 4:25 pm
Thanks so much for the pics, makes a difference to me seeing it. One more question, did you cut down the filter in port 3 to make it flush. Again thanks.
ManiacLachy
Engaged
Postby ManiacLachy » Mon Sep 24, 2018 4:46 pm
I broke one of the plastic tabs on the OEM one too :mrgreen:
No, those were the ports as I received them.
Badbuzzard
Postby Badbuzzard » Mon Sep 24, 2018 4:58 pm
Ummmmmm, one more question. Does it matter which way around the wiring is connected from the solenoid to the OEM female plug/
Postby NitroDann » Mon Sep 24, 2018 5:25 pm
No.
Postby KevGoat » Mon Sep 24, 2018 5:51 pm
Badbuzzard wrote:I do think the asco can be fitted better and looks neater but hey! I have the MAC so in it will go. Pictures make such a difference, to me anyway.
Well here's another then ... it can still be fitted pretty neatly...
Badbuzzard
Postby Badbuzzard » Mon Sep 24, 2018 6:32 pm
Thanks for that answer Dann and Cheers for the pic Kevgoat, that looks tidy enough for sure.
Badbuzzard
Postby Badbuzzard » Mon Sep 24, 2018 8:46 pm
So just a quick thanks to the people who offered up the assistance I needed today. Nearly all sorted just need to get my hands on a longer piece of 3/16 hose. Did do a pre run and all good. Many thanks again.
Badbuzzard
Postby Badbuzzard » Tue Sep 25, 2018 1:44 pm
Can someone tell me what the name of this part. It's on top of the rocker cover and the grey plug attaches to it. Spark lead is on the opposite side. Is this a coil? I need to buy one so if anyone knows best place to source one that'd be good. Was remove grey connector plug but didn't squeeze hard enough when pulling it off ( I know that sounds sexual) and broke small locator clip off. DoH!
Postby NitroDann » Tue Sep 25, 2018 1:46 pm
Coil.
Badbuzzard
Postby Badbuzzard » Tue Sep 25, 2018 2:13 pm
NitroDann wrote:Coil.
Thanks Dann, I'll do some searching for sales.
Badbuzzard
Postby Badbuzzard » Wed Sep 26, 2018 8:04 pm
So Mac valve installed and working well.
ManiacLachy
Engaged
Postby ManiacLachy » Thu Sep 27, 2018 7:47 am
Glad to hear you got it all worked out. :DIY:
Badbuzzard
Postby Badbuzzard » Thu Sep 27, 2018 7:12 pm
So I did a small service today, Oil, oil filter and plugs. Was someone "taking the piss" putting the oil filter in an almost inaccessible position. Probably not so bad if your cars an American version, they'd have less crap in the way just guessing. I unfortunately have large forearms and I'd hate to have short arms!, by gee it was bloody difficult. I can see why people install those filter relocation thingys. Anyway, done now.
