Replacement Dash Vents
charcoal
Re: Replacement Dash Vents
Postby charcoal » Sun Aug 26, 2018 6:04 pm
Sadly, the SX4 vents do NOT fit as they are a larger diameter :(
...and when looking at them from the outside, there are three flaps rather than the two on the Mitsubishi item.
Back to the drawing board
Postby Hammer » Wed Aug 29, 2018 7:47 pm
I saw those too (SX4 vents) when I was looking for the Eclipse vents, and nearly tried it. :D It seems many have been buying the dash vents from the Eclipse lately. They are selling quick in eBay, and prices have gone up.
charcoal
Postby charcoal » Mon Sep 17, 2018 2:53 pm
...strike two!
I managed to find smaller vents with the two swivelling flaps from the same o/s eBay supplier. They don't have the outer ring and are a light grey colour. They are also shorter depth and looked like they were going to "do the trick", but once again weren't able to be used for the task.
At least my total outlay so far has only been less than $A20, so I now have to decide whether to have another try or just put up with the original vents... :roll:
Postby Lokiel » Tue Sep 18, 2018 10:16 am
... or just buy the Eclipse vents?
charcoal
Postby charcoal » Tue Sep 18, 2018 12:00 pm
With a bit of persuasion, I have decided that they do fit after all (?)
I'm not really convinced, however will give them a try as I can revert to the originals fairly easily if they don't do the job for us.
I'm not prepared to go to the trouble/expense of buying the Eclipse vents, particularly if some un-reversable modification is required to make them fit.
Postby KevGoat » Tue Sep 18, 2018 12:33 pm
No non reversible mods required to fit the eclipse vents. They are the tried and proven method and work well, can swivel, direct the air as wanted and close individual vents off. Nothing wrong with trying new ideas, just that it can often prove more costly in the end.
Users browsing this forum: No registered users and 100 guests
