2.5 swap lets talk cams
- Custardtart
Pretty much got everything needed to do this now (except a spare couple of weekends!) and have decided on a cam upgrade at the same time.
I've heard about Moto East's 1.5 cams but they seem a tad mild. I'm after a bit more, can be a bit lumpy but needs to still idle in traffic ok.
I was thinking I'd give Deckspeed a call but wondered if anyone on here had any other useful info?
NC1 - 2.5 opposite lock device
Lakeside 62.3
Lakeside 62.3
- StanTheMan
Re: 2.5 swap lets talk cams
What profile are the standard ones?
I had mine cams swapped. Deckspeed got me a set of mild cams. The engine is now smoother than the OE cams, revs better and levels the torque curve. BUT power hasn't changed much if at all.
2008 NC 2.5l conversion, Tein edfcpro, 4.1diff and a big smile
- Custardtart
StanTheMan wrote:What profile are the standard ones?
Mines a 2011 Mazda 6 engine but below is the cams for the various engines and vehicles used for 2.5 swaps.
I haven't yet found out the profiles for the oem ones but I've heard some interesting info that the 2.0l cams are VERY similar in profile to the mild cams out there.
Intake L3E312420
Mazda 6 - 2003, 2004, 2005, 2006, 2007, 2008
Miata - 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013
Intake L3G212420A
CX-7 - 2010, 2011, 2012
Mazda 3 - 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013
Mazda 5 - 2008, 2009, 2010, 2012, 2013
Mazda 6 - 2009, 2010, 2011, 2012, 2013
Tribute - 2008, 2009, 2010, 2011
Exhaust L30912441A
CX-7 - 2007, 2008, 2009, 2010, 2011, 2012
Mazda 3 - 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013
Mazda 5 - 2006, 2007, 2008, 2009, 2010, 2012, 2013
Mazda 6 - 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013
Speed6 - 2006, 2007
Lakeside 62.3
Lakeside 62.3
- Custardtart
ozace wrote:I had mine cams swapped. Deckspeed got me a set of mild cams. The engine is now smoother than the OE cams, revs better and levels the torque curve. BUT power hasn't changed much if at all.
Thanks for that. I probably want to go a bit more aggressive but without the cam details it's hard to really know. However, I do think the main benefit will be shifting the torque higher up in the rev range for track use rather than massive power gains.
It's interesting that you found it smoother with the new cams?
Lakeside 62.3
Lakeside 62.3
It's much more usable now. Speak to deckspeed I know is about to do a more aggressive set than mine. Depending on how that works out I may do it as well
- Custardtart
ozace wrote:It's much more usable now. Speak to deckspeed I know is about to do a more aggressive set than mine. Depending on how that works out I may do it as well
Had an email chat with Michael at Deckspeed and they do either the mild or race cams at the moment. The race cams would probably need new springs and be very lumpy so I might just go for the mild cams, it's not massive deal to swap cams but it is a decent chunk of cash assuming I can't then sell my existing ones.
As for the tuning, I think I've got this right in that I can instal the cams and load the base map from ECUtek using a cable supplied by Deckspeed and a pc/tablet, then drive around producing log files (stored on the pc/tablet) which I send to Deckspeed who then supply a more finely tuned map. Does that sound about right?
Lakeside 62.3
Lakeside 62.3
I am not sure how the tuning works, I drove my car from mel to syd to get it done in their facility. I cant wait to hear how yours work out
- Custardtart
I've decided to use the 2.0l cams and see how we go. Below are some numbers that show the 2.0 offers a fair bit of improvement over standard 2.5 cams and considering the cheapest cams are around $1500 delivered I'll bank the saving for now.
Standard 2.5 cams: 254 duration, 9.3mm lift
Standard 2.0 cam: 268 duration, 9.3mm lift
Cosworth 270 duration, 10mm lift
Dynotronics 264 duration, 10.1mm lift
Lakeside 62.3
Lakeside 62.3
Can't wait to hear how it goes
- StanTheMan
Custardtart wrote:I've decided to use the 2.0l cams and see how we go. Below are some numbers that show the 2.0 offers a fair bit of improvement over standard 2.5 cams and considering the cheapest cams are around $1500 delivered I'll bank the saving for now.
Do the 2.0L cams fit the 2.5? I was under the impression these blocks are now lazer cut like....every block is a different size or each block is proportionally sized depending on size.
edit* Maybe I'm thinking ND ...Not NC.
- StanTheMan
super excited for you regardless....
I want Patchy back.
I want Patchy back.
The cams should be matched to what you want from the engine as well as the head.
I assume that you are doing no head work?
- Custardtart
StanTheMan wrote:Custardtart wrote:I've decided to use the 2.0l cams and see how we go. Below are some numbers that show the 2.0 offers a fair bit of improvement over standard 2.5 cams and considering the cheapest cams are around $1500 delivered I'll bank the saving for now.
Straight swap. I have to admit that I'm very tempted to just swap the 2.0 head over given I'm going SC it probably makes little difference that the 2.5 head outflows the 2.0.
Lakeside 62.3
Lakeside 62.3
- Custardtart
Magpie wrote:The cams should be matched to what you want from the engine as well as the head.
No head work, keeping it simple and low cost
Lakeside 62.3
Lakeside 62.3
