Was a busy weekend getting everything finished. The pre alignment values were 'interesting', so much for marking the alignment bolts before pulling them out. LR toe +13 and FL toe -26.4mm
Running a slightly different alignment to previous, dialed some rear camber out to help with grip out of the corners.
Front
- Caster L/R 4°01' 4°01'
- Camber L/R -3°29' -3°27'
- Toe L/R -1.4 -1.3
Rear
- Camber L/R -2°28' -2°29
- Toe L/R 1.2 1.2
Took advantage during the alignment at Hacketts Discount Tyres to calibrate the steering angle sensor. A simple job really, but required the steering wheel to be turned at least 20°and I do not have turn plates in the shed
Steering by Eipeip, on Flickr
Racepak sent over the cable to hook up the RPM to the CL-1. Now have the RPM working which now means I do not have to manually start the recording. Happy to put in another car at the track one day to get thoughts on the CL-1.
