MX5 cars, coffee & Nasho run- SEQ edition
Queensland Events
JBT
Re: MX5 cars, coffee & Nasho run- SEQ edition
Postby JBT » Tue Aug 21, 2018 6:18 pm
:shock: We'll have to find smoother roads for you next time Daffy. :wink:
Red_Bullet
Vehicle: NA8 - Supercharged
Postby Red_Bullet » Tue Aug 21, 2018 7:41 pm
Daffy wrote:May need to check the stiffness of the front suspension...... some slight scrubbing on them bigger dips :lol:
https://www.youtube.com/watch?time_continue=14&v=jjsocJxdlYA
mazdaz
Vehicle: NC - LE
Postby mazdaz » Fri Aug 24, 2018 10:25 am
I have a guard roller?
ManiacLachy
Engaged
Postby ManiacLachy » Fri Aug 24, 2018 11:24 am
I don't think the tyre is hitting the fender, it's the liner and the "spats" on the rear arches of the SE. At least, that's what it is for me in my car.
I've just picked up some shock spacers from our good friends at Beavis Motorsports that I hope will solve my problem. I'll be doing some install and testing soon.
Daffy
Postby Daffy » Fri Aug 24, 2018 9:11 pm
ManiacLachy wrote:I don't think the tyre is hitting the fender, it's the liner and the "spats" on the rear arches of the SE. At least, that's what it is for me in my car.
I got some overdue suspension homework to do me thinks!
viewtopic.php?t=73496
Red_Bullet
Postby Red_Bullet » Sat Aug 25, 2018 10:33 pm
More info
https://www.youtube.com/watch?time_continue=143&v=mdKD2qZ4sEI
Daffy
Postby Daffy » Sun Aug 26, 2018 1:28 pm
More info
Thanks for the link- I’m also reading through The American recent posts with his new MCA’s..... :DIY:
Red_Bullet
Postby Red_Bullet » Sun Aug 26, 2018 2:59 pm
Daffy wrote:
More info
Not particularly recommending any particular manufacturer but the info about setting ride height/ bump travel is important, I had to do my Coilover setup twice after discovering this info. Ride height is set by spring perch adjustment, NOT by Shock body length. Magpie has had a lot of input into this same subject on another post here somewhere.
JBT
Postby JBT » Sun Aug 26, 2018 8:56 pm
I get what MCA have published (have their product on the BMW) but Tein (have Flex Z on the MX-5) recommend the opposite. :roll: :(
https://www.youtube.com/watch?v=ozz7HLIhaEI
I would like to raise the rear of the MX-5 by about 5mm but have to maintain minimum recommended engagement in the lower "cup" if extending the shock body so, this change is barely achievable. The problem with raising the spring perch to lift the ride height by that amount, is that you end up with spring bind as others have discovered.
So confusing.
Postby Magpie » Sun Aug 26, 2018 10:31 pm
Not trying to derail this thread, but even BC Racing’s instructions is to set the ride height via the lower perch.
The reason they do not provide the instructions for setting length first then ride height via the spring perch is the time it takes. Most times out of the box is sufficient and good enough, however it may not be perfect.
I’m happy to help people set them up the long method if they have time (and I’m not busy).
Red_Bullet
Postby Red_Bullet » Mon Aug 27, 2018 11:49 pm
^^^^ Yes it takes a good deal of time.
Daffy
Postby Daffy » Tue Aug 28, 2018 9:01 pm
Magpie wrote:Not trying to derail this thread, but even BC Racing’s instructions is to set the ride height via the lower perch.
This is the great thing about doing runs like these for those of us that dont get to see some regular track time- good networking and quality imput from those with the groundwork experience- definitely nil derailing the thread mate, this is the bonus of doing these runs and getting a good de briefing from it :BROADY:
Gladiator
Postby Gladiator » Wed Aug 29, 2018 6:35 pm
^What Daffy said.
Return to “Queensland”
