Robbo's Clubbie Racer
Discussion regarding putting a non MX-5 engine in your MX-5, Exocet, Locost, FM Westfield and other MX-5 based kit cars.
Moderators: timk, Stu, zombie, -alex
beavis
Re: Robbo's Clubbie Racer
Postby beavis » Wed Apr 18, 2018 12:12 pm
It isn't required to run the car.
GR124
Vehicle: MX5 Locost
Postby GR124 » Wed Apr 18, 2018 12:21 pm
beavis wrote:It isn't required to run the car.
So just to confirm the detent is not required for the operation of the gearbox?
Oh, and thanks for the shift boots Beavis, received :)
Postby manga_blue » Wed Apr 18, 2018 12:36 pm
The gearbox neutral switch is one of the inputs for the ECU to determine idle speed. I think that's its only function.
GR124
Vehicle: MX5 Locost
Postby GR124 » Wed Apr 18, 2018 12:44 pm
manga_blue wrote:The gearbox neutral switch is one of the inputs for the ECU to determine idle speed. I think that's its only function.
after some research I gathered I should leave that one alone. Cheers Manga Blue
Postby manga_blue » Wed Apr 18, 2018 3:22 pm
As far as I can tell the ECU uses neutral switch, clutch switch, TPS closed switch and ECT output to work out whether it needs to idle and how fast it should idle. 3 out of the 4 working seems to be enough though.
GR124
Vehicle: MX5 Locost
Postby GR124 » Tue Aug 14, 2018 9:53 am
A little update on progress
chassis painted, great milestone, no more fabrication = Cleaner shed
floor fitted
removable panel for servicing
Postby 93_Clubman » Tue Aug 14, 2018 10:58 am
Looking good!
Postby bruce » Tue Aug 14, 2018 4:06 pm
Looks great.
GR124
Vehicle: MX5 Locost
Postby GR124 » Wed Aug 15, 2018 2:40 pm
bruce wrote:Looks great.
93_Clubman wrote:Looking good!
Cheers guys, this is good time of the build when you start to bolt together shiny clean stuff.
GR124
Vehicle: MX5 Locost
Postby GR124 » Wed Oct 17, 2018 10:21 pm
A little update for the people who like photos
adjustable defuser
engine going in for the last time (i hope)
made up some hydraulic lines
Postby 93_Clubman » Fri Oct 19, 2018 9:27 am
Clubbie looks great, as does your shed!
GR124
Vehicle: MX5 Locost
Postby GR124 » Mon Nov 05, 2018 8:43 am
we have some paint, moving in the right direction
bigdog
King of the kennel
Postby bigdog » Mon Nov 05, 2018 12:34 pm
GR124 wrote:we have some paint, moving in the right direction
Love it!
This is mine:
greenMachine
Postby greenMachine » Mon Nov 05, 2018 1:18 pm
Geeze Bigdog, get the front of those guards down :shock: . Those things have the aero characteristics of a brick, but you have made them worse still :lol: Otherwise, I love it, especially the polished aluminium!
That single hoop probably dates the car somewhat, I doubt that it would pass muster as a new build?
:mrgreen:
GR124
Vehicle: MX5 Locost
Postby GR124 » Mon Nov 05, 2018 1:40 pm
Bigdog, she looks like a historic job? looks very well presented. what's powering her?
Return to “Engine swaps, Exocet, Locost & MX-5 kit cars”
Users browsing this forum: No registered users and 18 guests
