I have a 1995 NA8 that needs a new radiator, any recommendations on replacement, I am located in Melbourne.
Many thanks
Radiator Replacement
- Learner Driver
Re: Radiator Replacement
Do you want recommendations on a replacement rad, or recommendations on someone to replace a rad, or both?
- StanTheMan
- LiteIsRite
If your car is stock, I can't think of a reason to replace with other than the stock OEM equivalent. I've been looking into this myself as mine will need replacement before summer. I plan on buying one of these - https://www.ebay.com.au/itm/MAZDA-MX5-NA-1-6ltr-1-8ltr-1989-1997-MANUAL-RADIATOR-KOYO-QUALITY-/322049824026.
”How you get there is the worthier part.” - Shepherd Book, Firefly
"Cherry" - Classic Red 1990 NA6 [sold]
LiteIsRite wrote:If your car is stock, I can't think of a reason to replace with other than the stock OEM equivalent. I've been looking into this myself as mine will need replacement before summer. I plan on buying one of these - https://www.ebay.com.au/itm/MAZDA-MX5-NA-1-6ltr-1-8ltr-1989-1997-MANUAL-RADIATOR-KOYO-QUALITY-/322049824026.
I think that may be what's in mine or at least it's branded Koyorad so won't be too different. Looks very OEM though I know it isn't original. MX5 Mania apparently recommended the previous owner change it as the tank was the typical very brown colour they go before failing so it was replaced along with all water hoses.
'97 Neo Green limited edition
- Learner Driver
93_Clubman wrote:Do you want recommendations on a replacement rad, or recommendations on someone to replace a rad, or both?
Both. Thank you.
Car is stock.
If in far southeast, for anything MX5: Gerald & Chaz @ Mammi Motors, 10 Industrial Drv, Somerville, 5977 7973. Otherwise any good mechanic or radiator shop.
Following is a popular replacement:
Alternatively, some go for an ASI 42mm (52mm not required for standard MX5) full aluminum rad:
https://www.ebay.com.au/itm/Aluminum-Ra ... SwCU1Yr8~N
I bought the ASI 42mm rad from ebay over a year ago and it's been great and very reasonable price.
- Learner Driver
DTH wrote:I bought the ASI 42mm rad from ebay over a year ago and it's been great and very reasonable price.
Thank you
Users browsing this forum: No registered users and 98 guests
