bruce wrote:Just weld up the rear doors in the Mazda 3, cut the roof off and voila......you've ruined a Mazda 3.
Hah!
Custardtart wrote:Thanks for the update.
Is the 4.1 ok? I’ve been thinking of this but was concerned it might be a big jump from the 3.7?
StanTheMan wrote:So the lower diff ratio is all about fuel economy?
Sent from my SM-G935F using Tapatalk
hks_kansei wrote:StanTheMan wrote:would these go into an NA chasis?
Probably, google shows a couple at least.
Biggest issue is that unlike a B6 to BP swap where a whole lot stays lines up, with the MZR pretty much nothing does, even stuff as simple as exhaust and intake being on opposite sides to the B series.
If you wanted a 2 litre (without boring out a BP) it's probably a bit simpler to go for an F series engine, probably the FE-DOHC (FE3 colloquially)
Intake/exhaust on same sides, MX5 gearbox I believe can fit if you use a B series ute, or E series Van bellhousing (or 929, but they were auto only)
But, you're still stuck with custom sump, and probably having to do something about the subframe.
Plus, the F engines are physically taller than a B engine, so you'll probably need to have a small bonnet hump or something to clear.
ozace wrote:The drive back from Sydney had me 500rpm higher in 6th but it wasn't annoying with the added plus of not needed to drop down to go over a hill. I am very pleased I did it
