NC 2.0 to 2.5 swap
Re: NC 2.0 to 2.5 swap
Postby hks_kansei » Mon Apr 23, 2018 1:21 pm
If it were me, assuming the 2.5 block shares the same codes as the 2.0, i'd just put it in and update the engine number with RTA or whatever QLD call theirs.
it's not like the police will pull the head off and measure the bores/crank.
emilmh
Vehicle: NC - LE
Postby emilmh » Mon Jun 04, 2018 9:36 pm
Custardtart wrote:
bruce wrote:If u Engineer it add a minimumn $1000 (or easily double that).
Having had a look at the Qld transport website it looks like this engine swap doesn’t need engineering.
Under what rules do you you think it’s not required?
My impression is that it needs a mod plate (if that’s what you mean by “engineering”) as the 2.5 was never offered as an option, I was reading the rules earlier tonight about wheels and composite panels and skimmed over a few engine bits.
But also, no one would know that it is different by just looking at it, so pretty safe as far as roadside defects go.
Custardtart
Postby Custardtart » Tue Jun 05, 2018 7:41 am
It’s within the 20% power rule
NC1 - 2.5 opposite lock device
Lakeside 62.3
StanTheMan
Postby StanTheMan » Tue Jun 05, 2018 8:05 am
but its not within a lot of other rules
Custardtart
Postby Custardtart » Tue Jun 05, 2018 8:53 am
https://www.tmr.qld.gov.au/-/media/Safety/Vehicle-standards-and-modifications/Vehicle-modifications/Light-vehicle-modifications/NCOP/4sectionlaengine.pdf?la=en
Looks like it needs a LA1 certificate but there’s some ambiguity about page 6. Scope, 1.1 Base Modifications Not Requiring Certification.
The engineer who did my roll bar said he didn’t believe it would need engineering.
Welcome to the world of mod plates :mrgreen:
Lakeside 62.3
StanTheMan
Postby StanTheMan » Tue Jun 05, 2018 9:18 am
Right lol
Sent from my SM-G935F using Tapatalk
Postby NitroDann » Tue Jun 05, 2018 10:57 am
It won't need engineering, a blue slip for change of details will be fine.
Postby Regie » Wed Jun 06, 2018 5:52 pm
Lucky you, it needs engineering here in NSW
Postby bruce » Wed Jun 06, 2018 7:30 pm
Anything goes in Qld. U could probably mod plate am LS swap.
Postby Regie » Fri Jun 08, 2018 11:36 am
bruce wrote:Anything goes in Qld. U could probably mod plate am LS swap.
there is a MX5 sitting at Bullet cars in QLD with a Toyota V12 in it :D
Postby bruce » Fri Jun 08, 2018 12:12 pm
A Century motor! Any pics? Does it even resemble a 5 anymore?
