Coilovers
Coilovers
Hi
After a lot of research I have ordered a set of V-Maxx xxtreme coil overs for my SE.
They appear to be good value for money and recommended by FM.
They cost me $800 landed from Germany. BC's are $1250 ,with GAZ out of the UK I would have to pay import duty and GST,I asked them to make two packages but they would not.
Will give my opinion when they are fitted.
Steven
Steven
- KevGoat
Re: Coilovers
Did you go the Classic or adjustable?
Re: Coilovers
Hi Kevin
I bought the adjustable ones
- KevGoat
Re: Coilovers
That is a good price then, much cheaper than from FM. From the FM site I'm guessing these are the 391/258 lb/in springs (roughly 7kg/4.5kg). I'll be very interested in your thoughts once you've dríven on them for a while.
- Learner Driver
Re: Coilovers
Yeh, I'm also interested to hear how these go.
Re: Coilovers
Have the rears in ,easy! A problem removing the passengers front, the two nuts holding the hat have rounded and will not budge!
- KevGoat
Re: Coilovers
wasp47 wrote:the two nuts holding the hat have rounded and will not budge!
You need some of these bolt grip sockets, have saved me plenty of drama removing rounded or damaged nuts/bolts over the years ...
Re: Coilovers
Regular 6 flats sockets will probably do the job too.
- greenMachine
Re: Coilovers
NitroDann wrote:Regular 6 flats sockets will probably do the job too.
KevGoat wrote:You need some of these bolt grip sockets, have saved me plenty of drama removing rounded or damaged nuts/bolts over the years ...
Wuzzes! Angle grinder FTW!
- Learner Driver
Re: Coilovers
What happened!!??! http://www.mx5cartalk.com/forum/viewtopic.php?f=44&t=76637
- ManiacLachy
- Engaged
Re: Coilovers
I'm curious too, but didn't want to derail the For Sale thread.
Not to your liking?
Not to your liking?
- KevGoat
Re: Coilovers
Same here ...
- OMX542
- Learner Driver
Re: Coilovers
Can the OP please update this thread on his opinion on these coilovers?
I tried to purchase a set a week or so ago from the same eBay seller, only to have them rejected by customs and returned to Germany (apparently the seller's paperwork was incorrect or insufficient).
Now I'm wondering whether I should take it as a sign and just go yellowspeed next time I find a 10% off coupon...
- KevGoat
Re: Coilovers
What sort of opinion can be formed from 100kms?? Take longer for them to settle before adjusting and a decent wheel alignment to suit ...
Re: Coilovers
Hi
I only had them on for short time, the new owner asked for the factory suspension to be put back on, my initial opinion is that they are excellent, IMO far better than the other well known brand of coilover they replaced.
Steven
Steven
Users browsing this forum: Bing [Bot] and 1 guest
