Kirk's '94 Clubman Mx5
Dehamsta
Re: Kirk's '94 Clubman Mx5
Postby Dehamsta » Mon May 21, 2018 10:47 am
Keen to see the progress!
The only negative is that it will most likely be harder to sell than if u kept it stockish.
Sent from my BLA-L09 using Tapatalk
lonesailor
Postby lonesailor » Wed May 23, 2018 12:34 pm
I would be interested in the NB's stock 15" wheels if you are selling and the price is right.
rascal
Postby rascal » Thu May 24, 2018 7:48 am
lonesailor wrote:I would be interested in the NB's stock 15" wheels if you are selling and the price is right.
NB8Bs have 16” rims...........
StanTheMan
Postby StanTheMan » Thu May 24, 2018 5:43 pm
kirkt wrote:So I have bought a Nb8b... for cheap!
This particular nb8b has some panel damage so I thought this would be the perfect candidate to swap absolutely everything into the clubman. I'm thinking driveline, subframes, vvt engine, interior and all electrics... The best of both worlds.
In saying that I will be parting out most of the NA... minus any crucial bits needed in the conversion. I will also sell off the remaining NB items, so please if you want first dibs on anything do let me know and I'll write your name down on my list of parts.
The conversion will most likely happen late June, early July.
Driveline is totally un neccecary. You have essentially alraedy got most of that plus more.
Ok brakes. For sure. ABS....ƒü¢k YEA....
VVT.....NIce touh. 10:1 cR....ohhhh boy.
But it aint a clubman anymore.
Apart from the sticker and manual steering.
Id keep the old engine....put it back in.....when the time comes
Sent from my SM-G935F using Tapatalk
kirkt
Vehicle: NB8A - Supercharged
Postby kirkt » Fri May 25, 2018 2:29 pm
Dehamsta wrote:Keen to see the progress!
I'm not too worried about resale. I'd much rather modify and enjoy it.
I will probably use my nb8a stock wheels and sell the nb8b stock 16"s.
StanTheMan wrote:Driveline is totally un neccecary. You have essentially alraedy got most of that plus more.
For the ease of the conversion I'll just be dropping both subframes with everything attached and replacing them with the NB setup.
Unfortunately when I bought the car the original engine had been replaced so I'm not too concerned about 'keeping it stock' or that it's not an 'original clubman' anymore. I'd rather just enjoy it for what it is and will be.
'94 Clubman Mx5
lonesailor
Postby lonesailor » Mon May 28, 2018 1:05 pm
I would still be interested in the 16" wheels as long as they fit my NA8 and I can buy some decent tyres for them
kirkt
Postby kirkt » Sun Jun 10, 2018 4:49 pm
I managed to sell the shell with panels and lights to a bloke who is planning to swap everything from his sons crashed mx5 into this one. Luckily he was nice enough to offer his workshop + tools to seperate the unibody from the driveline. In the near future I plan to split my clubman and get this conversion rolling. See below.
'94 Clubman Mx5
kirkt
Postby kirkt » Sun Jun 10, 2018 4:52 pm
Parts will become available from the NA very soon. Do message me if you want anything. Motor pending.
'94 Clubman Mx5
kirkt
Postby kirkt » Fri Aug 17, 2018 5:14 pm
So quite a lot has happened since my last update... See below.
So the last pic is how the car currently sits. I will be dropping the existing NA subframes this weekend and finishing odds and ends ready for the NB gear, which should be in, in the next couple weeks. I'm very excited about finishing this as it's been a couple months since driving it last.
Things I have to do still:
- Fuel system in engine bay
- wire up, door actuators, power mirrors and audio
- Modify NA catback exhaust
- Mount misc items in engine bay
'94 Clubman Mx5
ManiacLachy
Engaged
Postby ManiacLachy » Sat Aug 18, 2018 10:28 am
Big job, great work!
Postby bruce » Sat Aug 18, 2018 3:27 pm
One of my favourite ways to update an NA, apart from sticking in an SE engine.
That weird striped cam cover has got to go - stock would be good.
kirkt
Postby kirkt » Sun Aug 19, 2018 9:30 pm
So another huge weekend went by. To start things off I picked up the nb8b 'skate' on saturday and started tearing it down. Swapping out the rear subframes was pretty easy and straight forward... Just jack it up in place. The front however was a little more annoying. I had to call in a friend for help as I was planning to lift up the front of the NA and slide the engine from the front back, as it would normally sit. That part was simple enough.. however lining everything up from this point forward was a pain. In the end Matt (sky blue Nb) and I eventually got it. See below.
The bulk of the work is done which opens up a lot of windows for smaller jobs to be completed after work during the week. Hopefully it's pretty straight forward from here on.
'94 Clubman Mx5
Garido
Postby Garido » Tue Aug 21, 2018 12:35 am
Great work there Kirk. I really should update a build log of my 2. Loving the red :)
kirkt
Postby kirkt » Thu Sep 20, 2018 12:56 pm
So I'm about 95% done in terms of engine bay work and the car overall. The engine bay is mostly stock items minus the fuel pressure regulator. I removed the pulse dampener on the factory nb8b rail and installed some fittings to create the return line which mates up with the factory hardline after the FPR, Very simple system but works great... Until I noticed a fuel leak. I quickly found it was a leaky O-ring on one of the injectors. 4 New O-rings later and everything was working again leak free.
The almost completed Engine bay and cock pit.
The headlight motors will have to stay up until I wire up a custom harness for the headlight motors. I'm thinking either use the foglamp switch in cabin or replace it and use something else.
I also picked up an extremely cheap hardtop for my missos car. The drive was awesome too.
I have a few parts coming in but overall i'm extremely happy with how the car performs and how simple this conversion was.
'94 Clubman Mx5
kirkt
Postby kirkt » Thu Sep 20, 2018 1:02 pm
Off topic but has anyone here mounted a mountain bike to their mx5? Pic related, I want to mount this to the car in the future for transport.
'94 Clubman Mx5
