NA6 - did they have factory fitted front grill?
Should my 89 JDM NA6 have a factory fitted front grill in the air dam of the front bar? If not, where/how are the aftermarket ones that I see available for sale mounted?
Re: NA6 - did they have factory fitted front grill?
Nope. Rivets and bolts and the like.
As above, no factory grille, just an open hole and the radiator behind it.
Most of the aftermarket ones just mount with a couple of screws and small brackets.
Personally I think the grilles look rubbish, but different strokes etc.
- GCMX5
I made my own which fits with rubber friction.
Does not look obvious in its location. Keeps stones and bugs from damaging or blocking any of the coolers.
Fun in the Sun on the "GC" - oops, now in "PS"
Mindy the NA6
Morticia the NA8
Mindy the NA6
Morticia the NA8
- shirtz
GCMX5 wrote:I made my own which fits with rubber friction.
and significantly reduces airflow..
I wouldnt say significantly, depending on the mesh type.
Most stuff will still flow fine, unless it's that godawful drilled steel that was all the rage in the 90s.
- GCMX5
No concern with airflow at all.
Mindy the NA6
Morticia the NA8
Mindy the NA6
Morticia the NA8
