Postby bruce » Mon May 21, 2018 7:57 pm
Stan and lots of repetitive wrist polishing action!
Postby Mr Morlock » Mon May 21, 2018 8:11 pm
Okibi did a how to some years ago probably +5 yrs - part of the secret is using a bench polisher- doing it by hand is going to be a slow process. The other way is actually find a metal polisher - i.e. the bloke that does the work - they work fast and not necessarily expensive but not sure these days if there are many left. I do agree that it looks terrific- STM has done a mighty job - on old motorcycles it was a common thing to do that is polish the timing covers and primary chain covers- the allow I reckon looks even better than chrome.
StanTheMan
Postby StanTheMan » Mon May 21, 2018 8:13 pm
Experimenting with the heat shield.
Starting with the cam cover a few months ago
Seriously the plenumn was done like last year. But the same deal. Lots of hrs. Sometimes i used machines....but the deepes shine i get by hand.....ImageImageImage
Sent from my SM-G935F using Tapatalk
StanTheMan
Postby StanTheMan » Mon May 21, 2018 8:15 pm
Mr Morlock wrote:Okibi did a how to some years ago probably +5 yrs - part of the secret is using a bench polisher- doing it by hand is going to be a slow process. The other way is actually find a metal polisher - i.e. the bloke that does the work - they work fast and not necessarily expensive but not sure these days if there are many left. I do agree that it looks terrific- STM has done a mighty job - on old motorcycles it was a common thing to do that is polish the timing covers and primary chain covers- the allow I reckon looks even better than chrome.
Yoy could perhaos get it sandblasted which woould reduce the hrs sanding
Rocky
Concerned Citizen.
Postby Rocky » Mon May 21, 2018 8:50 pm
Fantastic result, Stan.
I am really envious as there is nothing I like more than "shiny".
It would be pretty impossible to do 'in situ' so I guess there is no chance of mine looking like that.
StanTheMan
Postby StanTheMan » Mon May 21, 2018 9:41 pm
AutoSol has 2 types of polish
Metal & aluminium.
Ive found the Metal stuff to better. Even on Aluminum.
Or at least to the naked eye....the metal polish just seem clearer...but its only a fraction
apsilon
Postby apsilon » Tue May 22, 2018 8:54 am
That's impressive work STM. I've done some small polishing jobs and would never consider tackling anything of that size myself.
Isn't the heat shield steel though which means it'll be a bit of a pain to maintain in that condition?
'97 Neo Green limited edition
Postby Lokiel » Tue May 22, 2018 9:55 am
StanTheMan wrote::
I found starting off with 80 grid leaves very deep scratches which a real hard to get out. Same with using stones
I had the OPPOSITE problem when I annodised black some of my aluminium pieces.
I wanted a brushed finish but couldn't find anything that cut deep enough for my liking so I settled on using thickly stranded steel wool and just brushing it firrmly and slowly in one direction several times - you can see it's a brushed finish if you look closely but it's not as "brushed" as I really wanted.
Polishing the intake manifold looks MUCH better than painting it - when they're painted and the paint starts flaking they just look ratty.
Your efforts look fantastic and I admire your patience. After doing just the rocker cover I would have thought you'd never attempt the intake manifold.
StanTheMan
Postby StanTheMan » Tue May 22, 2018 11:52 am
Yes all parts require maintenance. Water, fingerprints general humidity.will flatten the mirror shine especially on the polished alloy. It needs to be done every few weeks. I will probably spend 5 min each every few weeks and keep it maintained.
Unsure how diligent ill be with the heat shield to be honest cause there is also the enlarges alluminium Mania intake to be mauntained
StanTheMan
Postby StanTheMan » Tue May 22, 2018 12:00 pm
The old B6
Postby hks_kansei » Tue May 22, 2018 9:47 pm
Lokiel wrote:Polishing the intake manifold looks MUCH better than painting it - when they're painted and the paint starts flaking they just look ratty.
Ah, so you've seen my engine bay then :P
Postby Lokiel » Wed May 23, 2018 11:20 am
Please share photos!
Gladiator
Postby Gladiator » Sun Jun 03, 2018 12:14 pm
I fitted the chrome mirrors I picked up from Car Make Corns. The glass has a blue tint. I didn’t realise until I unpacked them at home. Luckily I like it.
LiteIsRite
Postby LiteIsRite » Sun Jun 03, 2018 4:36 pm
Finally got around to ordering and fitting anti-rattle springs to the rear brake pads. Big reduction in noise over bumps/expansion joints in the road, wish I’d done it sooner!
”How you get there is the worthier part.” - Shepherd Book, Firefly
"Cherry" - Classic Red 1990 NA6 :NA6: [sold]
Snowmotion
Postby Snowmotion » Sun Jun 03, 2018 11:45 pm
Installed Braided brake lines on the NC track car today.
I had to find a solution to mount the line to the A arm, I found this plastic piping that worked perfectly.
